Not knowing the condition of the motor of my 1965 VBB barn find the only solution was to rebuild it so that I could put at ease any concern I had about bearings, seals, "O"rings, etc.
I learned as I went. Replaced the following:
The Cruciform gear selector,
The rear wheel seal,
Kick Starter seal, gear, spring and pads,
Springs within the cush drive and new needle bearings,
New main seals on fly side and clutch side,
New crank bearings on both fly side and clutch side,
New piston, wrist pin and clips,
New cylinder,
New head, and plug,
New clutch plates and basket,
New rear brakes, castle nut and clip,
New stator, points and condenser,
New Coil,
Needless to say new gaskets all the way around,
I did not replace the main mounting rubbers as they appeared to fine.
Actually the main bearings looked great too but while it was apart I
replaced everything. I'm still running the original crank and rod. All transmission gears and gear tree looked like new. No wear could be found. Original machining marks was still visible.
After the rebuild I rode the bike for a season then tore it apart to start the body restoration. After completion of it for some unknow reason the darn thing just wouldn't start. It was then that I decided to convert it to a 12V CDI system. That solved all the starting problems and added all the fringes that a 12V system allows such as better starting, hotter spark, brighter lights.
