Hi all,
recently got a vespa ET125 back on the road after years off road. up and running.
Issue discovered today after about 2 or 3 miles (no more) the scoot just dies, lack of power. Almost like its overheated. I wait 10 mins and she starts again off we go for another 3 miles.
Doesn't feel like its over heated, my old cg125 would smell hot when i cooked that although i did see the oil light flicker?
Thinking its the carb as its been apart, jets clear, 2 3/4 turns out needle valve working great and stops when bowl is full.
I have found that the petcock is now broken, its always on. So a new one is on order could that over fuel?
would that be enough to cause that issue? checked the fan and all the blades look clear.
What does happen on the Vespas when they over heat? symptoms
thanks all
