Hello gentlemen,
I've bought GT 200 recently.
In general, it is in a very good shape for 28,000 km's (about 17500 miles).
Unfortunately, I wasn't able to reach speed higher than 100-105 km/h (about 60-63 mp/h)
I've changed all oils/liquids and when I've checked what is going on under vario cover - it doesn't seem to be OK in general.
Consumables are good, belt is 20.7mm wide (new is 21.0mm), rollers doesn't have any flat surfaces and are 20.6mm x 17mm (20.7mm x 17mm are new).
So, if belt and rollers are not the issue. Variator and pulleys are left.
Could You please share Your opinion, does it look worn out?
Another question, there was no washers at all and crankshaft seem to be worn out too, because of that, any ideas how to make it to live a little bit longer (I've ordered missing washers already).
Video of freeplay between crankshaft axis and variator bushing:
https://drive.google.com/file/d/1wo9VQR_tZjmXsgfzZ9AuhFUreiPJNrnc/view?usp=sharing
Thank You very much for help and participation!
