2006 Stella.
Headlight both high and low finally stopped working.
For a number of years it would shutoff when the headset was turned all the way to one side.
Hi-Lo switch appears to be working.
No continuity on main wire from regulator to H-L switch.
1) I'm thinking the wiring harness has to be replaced due to continuity issues. Looking for some alternative. Even if I could remove the headset and I spotted a break in the wire, I won't be able to patch it at that location where the wear is likely occurring? Is that correct?
2) regulator is putting out about 4 volts to the wire that goes to the H-L switch. This seems very low. I am confused by this. (The regulator was recently replaced in an attempt to eliminate that as an issue).
3) Other issues that popped up when investigating the headlight.
A) The turn signal switch to on causes neutral indicator light to blink, while turn signal indicators remain off.
B) Rear turn signals don't work, but front do.
C) Rear running light doesn't work. But, rear brake light does.
Any thoughts appreciated. Thank you
