MP3 Piaggio 2007
MP3 Piaggio 2007
Have been having vibration at stop when I pull the left brake lever. I've also noticed that on start up when I squeeze the left lever , the starter hesitates sometimes, like there is a bad connection. No problem with the right lever for front discs, no vibration, and starts everytime when using the Right lever. The vibrations are felt in the seat and handlebars. Should this be a concern ? Also breaking is quite minimal on the rear. I know we don't need much , but shouldn't there be more than a little ?
Keep those discs clean, Mine stops twice as fast after a good cleaning
THanks for any help, Dave
@jfredrik avatar
Suzuki Burgman Executive 650
@jfredrik avatar
David, I believe that is a normal situation, because both my wife's and mine act the same way. It's a minor vibration, but probably related to the fact that the engine is mounted on the rear swingarm. When the rear brake is on that vibration resonates through the entire chassis.
Anyway, that's my best guess. It doesn't seem to have an adverse affect on anything; so, I wouldn't worry about it!
@mcharris avatar
Piaggio MP3/250
@mcharris avatar
Piaggio MP3/250
I too have noticed this and I assumed it was because when the rear brake is applied it is transferring engine vibrations to the frame. But I have not gotten down, looked and verified the possibility my theory is plausible.
MP3 Piaggio 2007
MP3 Piaggio 2007
Brake Vibration
Thanks for the replys, I'm going to have that starter lag checked out next time I go in for sevice.
Dave
@brouhaha avatar
et4 and px150
@brouhaha avatar
et4 and px150
This can happen when the steering column nut is loose.
It happened to me... as soon as it was tightened, the shuddering stopped.
Get it checked out.
@billdbr avatar
Piaggio MP3 250
@billdbr avatar
Piaggio MP3 250
The same occured on my GT200. Definitely engine vibration transmitted through the frame. There was a tread the general discussion of this forum
Leo
@rotorymike avatar
MP3 / Scarabeo 500 / BV-250 / PAYMENTS
@rotorymike avatar
My MP3 does it as well when I pull the right brake at idle.
On the loose nut thory - is that on the MP3 or the regular scooter?
[ Time: 0.0330s ][ Queries: 3 (0.0244s) ][ live ][ 318 ][ ThingOne ]
