Hello
OK this is for my Dragster 180 but the setup is very similar to my GT200.
I have lateral movement on my rear wheel. It's not massive but it's been bugging me for a while. So today I stripped down the CVT and gear/drive box. I need to replace the bearing where the drive shaft connects to the rear wheel. Stripping the drive stuff down was a breeze but getting the bearing out has eluded me so far. The bearing sits inside a rubber grommet/bush.
While I'm in there I will probably change the other bearings as well. These look well jammed in and I'll cross that bridge when I come to it
I've probably explained that pretty crap so here is a picture hoping it will help explain better. Hoping you can help me get this mutha out ... TIA Mick
