2005 GT 200
2005 GT 200
just an FYI -
4,000 miles now on my '05 GT....
cleaned air filter; I was surprised by how clean it really was. however, next time i might just replace the thing as it's fairly messy to clean it.
oil - did get the 24 mm wrench....used one of those "strap" kinda wrenches you can buy at Sears to get filter off. worked very well.
coolant - much chat about coolant here, please let me tell you what i found on my scoot. i "topped off" yesterday with fluid type "per manual". checked here last night only to find that i really should be using an "OATs" type (no silicates, etc.). so i drained it today. color was green, exactly the same color of what i topped off with. flushed with 50/50 vinegar-water, then just water (distilled at all times), then filled up with Havoline DEX-Cool extended life. this stuff is RED.
my guess (and only a guess)....what i topped off with was probably same mixture as what came with the scoot.
FYI - to get a through draining of coolant system, drain then cover coolant cap with fingers and shoot a little compressed air (from a can is what i did) through a gap in your fingers. this will drain even more fluid.
all in all, these tasks were no big deal.
thanks
@jory avatar
2005 GT 200
@jory avatar
2005 GT 200
Can you get the DEX at any automotive store?
Thanks,
Jory
2005 GT 200
2005 GT 200
o'reilly's and auto zone had it
@scooter_d avatar
GTSie 250 - Black Its the New Red
@scooter_d avatar
where's the coolant drain plug located? And was it a big deal to do it?
thanks
2005 GT 200
2005 GT 200
no...very easy
unhook lower water line at water pump (exhaust side of scoot).
be sure to have a new 1" radiator hose clamp on hand (i used a 3/4 to 1 1/4 clamp from auto zone).
no big deal to do.
@scooter_d avatar
@scooter_d avatar
thanks for the information
[ Time: 0.0169s ][ Queries: 3 (0.0062s) ][ live ][ 318 ][ ThingOne ]
