drg wrote:
everyone keeps mentioning the emotional aspect... I mean sure. .Vespa's are just good looking bikes w/ a long history.. but theres one simple reason why they cost more...
The all steel chassis!..
Steel chassis? Yes. Steel body? No! The GTS I just gave back last week had quite a bit of plastic. It's damn nice plastic, but not "all steel." The inner leg sheild, glovebox, headset, and front fender are all plastic. That doesn't make it bad, but there are too many perpetuating the myth of the all steel modern Vespa. It's simply not true. And if it comes down to just having a steel chassis, then that could be said of many scooters.
A monocoque chassis can be very stiff. So can a properly triangulated tube frame. Look at the Italjet Dragster if you need an example.
drg wrote:
and don't even try saying that it doesn't make a difference.. it's a stiffer frame do to the WHOLE actual body of the bike being the frame.. vs a tubular steel frame inside.. with plastic fairings clipped on the bike... it's more durable.. if ure vespa goes down hard on its side.. u get dents and scratches vs cracked body panels (ever see those chinese delivery guys w/ there duct tape bodywork?).
And modern Vespas have both do contend with. If your front fender hits something in cold weather, it will crack. If you lay your bike down and damage your headset it will gouge and crack. It looks like it wouldn't be easy to bang up the inner leg shield and glovebox on the GTS and GT, but if you did, it would suck to fix it. The downside of steel bodywork is that it will rust. If you scratch it, your zinc primers are can actually create more rust in a scratched area in a shorter time than on metal that wasn't primed with sacrificial anode primers. If you don't fix and seal gouges right away, you're asking for big trouble down the line.
Additionally, new Vespas don't have removable cowls anymore. That was nice because they could be repaired or replaced easily. It is also good to have damage occur to non structural elements of the vehicle.
drg wrote:
Make no mistake.. pull out the bucket under the seat and look at the thickness of the steel and the reinforcing... it's like an old 50's car.. they just don't make vehicles like that anymore... and thus.. the extra cost...
Did that on my test GTS. The steel didn't seem to be of a thicker gauge than any car built in the last 10 years.
drg wrote:
another minor thing if ure buying new... ALL vespa's include roadside assitance free w/ it's warranty period.. and you have the option of extending the warranty an additional 2 years for an extra fee.. only the top of the line piaggio bikes include roadside assitance..and there is no extension...
Not very helpful when you're out in the middle of nowhere. Happened to a clubmate who was riding through Nebraska on her GT200. You get better coverage with AAA.
drg wrote:
while a Piaggio is definitly a good bang for your buck.. it always annoys me a little when people say that a vespa is just more expensive b/c of it's name.. it IS.. a higher quality bike...
With the GTS vs a Fly 150, I'm totally going to agree. If you pit the ET4 against the LT150, or the LX150 against the Fly 150, then you're paying more for a look, a name, and a little less plastic. There's nothing wrong with that, but Piaggio makes high quality products. I find it silly that people go on and on about how the steel construction is automatically higher quality than plastic. Plastic has some advantages and drawbacks, so does steel.
Plastic body panels aren't as cheap to produce as you think. The tooling for injection molding isn't cheap, and costs go up in an exponential fashion as part size increases, and if you have to make a mold that has more than 2 parts. If you're doing large, complex parts, then painting them, the cost savings really diminish.
When it comes down to it, the plastic/steel debate really is a wash. I wouldn't make a purchasing decision based on that factor. Find something you like the look, feel, and utility of. Assuming the after sale support is there, buy it and enjoy it. There are Vespas I would love to have. Other Vespas probably wouldn't win the race to my garage against comparable alternatives.
