Steve D wrote:
Thanks for the input, unfortunately still no life
Reset the blue key using the red/brown one.
Am going to strip and rebuild the carb as the problem only started after I cleaned out the jets.
Does anyone know if it is possible to re-program the CDi and if so how it's done as the only other thing I can think of at the moment is that the timing may be out??
I bet the problem is with the jets.
I caught it once after pulling my main out.
I 'thought' I had it wound all the way in but something made me look again and it still had an eighth of an inch to go.
The jet actually is seperate to the tube it sits in, so there are two sets of
threads to mindful of.
If the tube wound out and you didn't notice it's probably sitting in the fuel,
in the float chamber, flooding the bejesus out of it.
How did you clean your jets?
didn't poke a rusty nail down them did you?
anyway, for poor starting it's probably a blocked/not correctly seated
primer jet (the little one)
