How many of you have new Vespas, (1-2 years old), and are having electrical issues? My 1 year old GTS is having the electrical harness replaced due to an untraceable short.
2005 Dragon Red ET2, 1959 (Vespa) Allstate Crusaire
Posts: 177 Location: Ottawa |
While I had mine on Vacation in North Carolina My entire instrument panel went out. All the gauges, warning lights and turn signals. The headlight and tail light still worked as well as the brake light. I stayed out for about two days coming on from time to time. Then it just started working again and no problems since. (Knock on wood) I figured it was a moisture thing since my scoot normally does not sleep outside and it got rained on as well as a lot of riding in the rain. What are they charging to replace the harness??
It's going to be covered under the factory warranty since the scoot is less than 2 years old. I'm worried about next time in a year if this happens again, I'm sure the bill will be around $500 - 1000. Not a great thought for the future. I'm seriously thinking about selling my baby when it gets back. I can't afford $1000 a year on new wiring harnesses. That's a ridiculous expense if Vespa's have weak harnesses.
I have no electrical problems, knock on wood, but I am curious what some of your issues were. Also when they extract the old harness out, please look the harness over good, I mean really good. Look for any frayed wires or a rub point somewhere. Note where the rub point was so you can report back to us on where and what was done.
Spot |
'07 GTS-250ie - sold and gone
Posts: 2023 Location: the Queen City of the West, aka Porkopolis |
I've swapped posts with a few people who've had electrical trouble, generally wiring shorts:
GTS 250 Cooling Fan Stays on Now, as luck would have it, I'VE got one too: the water temp bargraph is intermittant. Sometimes shows the flashing boxes on either end, indicating a short or open to the sensor. The wiring design (materials, routing, mounting, etc) doesn't seem quite robust enough. |
64 Allstate Cruisaire, 2007 LX150 & 2007 GTS250
Posts: 90 Location: SW Ohio |
John,
Some of these electrical issues sound like problems with shorts in the actual wiring/wiring harness - others involving the instrument panel sound like they might be related to connections of the wiring to the circuit board. What do you think? |
GTS 300 Super, 76 Sprint Veloce, Ape
Posts: 619 Location: Toronto Ontario |
out of 300 bikes sold we have repaired 4 electrical issues.
3 minor and 1 pretty good one. I feel thats pretty darn low!! Electrical issues become very common with the label "made in china". |
kar1205 wrote: John, Some of these electrical issues sound like problems with shorts in the actual wiring/wiring harness - others involving the instrument panel sound like they might be related to connections of the wiring to the circuit board. What do you think? The nasty thing about these problems is that shorts/opens are so fiendishly hard to find - tracing wires in mounted harnesses is absolutely no fun. Very often it turns out that the shop just gives up finding the fault and replaces the whole harness, which in a lot of cases is a cure worse than the desease. VespaBurlington, I'm sure you're right about the your problem rate being low; maybe it is that anybody who has a problem comes right here to MV to report. I've come across quite a few electrical problems in the course of brousing the forum. Anyway, I'm happy to see a dealer here amongst us. BTW; I drew up my own wiring diagram of the GTS because the diagram in the shop manual is so illegible. The file is too big to upload to the forum; if anybody's interested, I'd be glad to e-mail it to 'em. ⚠️ Last edited by Cincinnati John on UTC; edited 1 time
Cincinnati John wrote: I drew up my own wiring diagram of the GTS because the diagram in the shop manual is so illegible. The file is too big to upload to the forum; if anybody's interested, I'd be glad to e-mail it to 'em. |
Re: electrical issues anyone?
GTSBERG wrote: How many of you have new Vespas, (1-2 years old), and are having electrical issues? My 1 year old GTS is having the electrical harness replaced due to an untraceable short. |
jrsjr wrote: Cincinnati John wrote: I drew up my own wiring diagram of the GTS because the diagram in the shop manual is so illegible. The file is too big to upload to the forum; if anybody's interested, I'd be glad to e-mail it to 'em. |
ScooterME wrote: Bad thing is the dealer is having a hard time getting hold of a harness! Here are the threads about wiring problems I've seen so far: GTS 250 Cooling Fan Stays on GTV blowing fuses GTS Fan relay location? We should declare this thread THE home for GTS wiring problems. ⚠️ Last edited by Cincinnati John on UTC; edited 1 time
Cincinnati John wrote: jrsjr wrote: Cincinnati John wrote: I drew up my own wiring diagram of the GTS because the diagram in the shop manual is so illegible. The file is too big to upload to the forum; if anybody's interested, I'd be glad to e-mail it to 'em. Please email the files you have and I will see about getting them posted up properly here. Thanks. I'm sure others are interested in what you put together. Tom ⚠️ Last edited by Tikka on UTC; edited 1 time
Thanks John, Got the files. Please post up a new thread in General. Then I can modify that (files are already set to go up) and have it moved into the tech area.
