@rp_tech avatar
BV-350T, BV-400S, Malaguti 150
@rp_tech avatar
After 5 weeks with the new scoot I decided to adjust the 2 rear shocks on the 2018 GTS 300. It came with the factory setting at the softest but would bottom or top out going on & off curbs. I'm at 245lbs.
I moved each just one notch and immediately felt an improvement. Curbs are softer now.
Is there a guide to let me know where the adjuster should be. I know the opposite extreme is for pillions.
thanks in advance, Ralph
2023 Genuine Buddy 125
I bumped my Liberty shock up to 4 out of 5 for two-up riding and it really did smooth out the ride.
@paul_g avatar
GTS 250ie
@paul_g avatar
GTS 250ie
Whatever works is fine. Depends on your weight, your riding style, the roads you're on.
There is no wrong answer.
@touring300 avatar
@touring300 avatar
Re: rear shock adjustment
RP Tech wrote:
I'm at 245lbs.
If I were you I would be very careful about riding on and off curbs. You are storing-up potential problems for the future with possible damage to wheel and steering bearings.
@waspmike avatar
@waspmike avatar
@rp_tech avatar
@rp_tech avatar
If I were you I would be very careful about riding on and off curbs. You are storing-up potential problems for the future with possible damage to wheel and steering bearings.[/quote]
That's good advice Touring300. Thanks. Lucky for me the curb I'm referring to is at the end of the driveway. It rises 5 mm = 2"off the street. I always roll over it at an angle to lessen the load on my shock.
Recently we rode over rail road tracks and I scanned for an level and even section. I find going perpendicular to the rail is comfortable.
So far, riding 120 miles at shock detent #2 is a definite improvement for me. I'm tempted to click it another notch to #3. Any advice considering there is an additional 250 lbs / 114 kg of sprung weight.
[ Time: 0.0125s ][ Queries: 3 (0.0063s) ][ live ][ 319 ][ ThingOne ]
