"Started as a spark plug post..." is rather long and this is actually a question about fuses that might benefit other 2015 GTS300 owners...
I'm having starting issues (see other post, if you want), so I'm trying to check the starting wiring (including fuses) using the 2015 GTS300 service manual and a wiring diagram. To my surprise the service manual and wiring diagram have different fuse configurations from each other and both fuse configurations differ from the LABELED fuse box in the bike itself. Does anyone know the correct configuration?
From the ABS-specific 2015 GTS300 service manual:
Fuses
The electrical system is equipped with:
1. six protection fuses «A» located in the glove
compartment to the left
2. of a fuse «B», located in the battery compartment.
FUSE «B»
Specification Desc./Quantity
1 Fuse no. 1 Capacity: 30 A
Protected circuits: Main system.
FUSES «A» ABS VERSION
1 Fuse no. 2 Capacity: 7.5 A
Protected circuits: Inclination sensor, starter button,
control unit, immobilizer aerial, ABS control unit.
2 Fuse No. 3 Capacity: 10 A
Protected circuits: Control unit.
3 Fuse No. 4 Capacity: 7.5 A
Protected circuits: Pre-installation for anti-theft device,
turn indicators, horn, lights relay, stop lights, USB socket.
4 Fuse No. 5 Capacity: 15 A
Protected circuits: Front headlight, electric fan, Pre-installation for anti-theft device, instrument panel, ignition
switch.
5 Fuse No. 6 Capacity: 7.5 A
Protected circuits: Taillight, instrument panel, front turn
indicators.
6 Fuse No. 7 Capacity: 20 A
Protected circuits: ABS control unit.
Also, the service manual numbers the fuses ascending from right to left (there's a photo), so the fuse order as given in the manual's picture (shown by me from left to right) is: 7, 6, 5, 4, 3, 2. Fuse 1 (30A) is in a different location by the battery.
The wiring diagram lists 9 fuses.
The LABELED fuses (I pulled them out - there are labels as to the types of fuses to put in each slot) in the glove box compartment are:
