I recently fitted a 130 front and 140 rear Michelin Pilot City tires and wondered what the new discrepancy in the speedo was. Jess did this way back in 2005 with stock tires [topic40] I didn't make a graph, but you can see that the tire difference closed the difference down a bit, but not nearly as accurate as I would have liked.
I got ahold of a Garmin GPS unit and went out and did some comparisons with the speedo. There was a bit of discussion about this on whos running 140's on their rear 250? and so I found a GPS unit and here is what I found.
1st number: speedo reading
2nd number: GPS reading
40mph-37.5mph
45mph-42.5mph
50mph-48mph
55mph-53mph
60mph-58mph
65mph-63mph
70mph-67.5mph
75mph-72.5mph
80mph-76.5mph
84mph-81mph (only could achieve this speed in a full tuck)
small vespa windscreen, topcase, PM pipe, 5525 miles, 155lb 5'10" rider with gear and 81 mph in full tuck. I can hold 77-80 indicated on flat ground without tucking. YRMV.
good day, jason
