kz1000ST wrote:
First off, the topic was about moving weight. A 650 Burgman weighs 600 pounds no matter how you slice it. Dragging 600 pounds out of a garage is still 600 pounds.
You 'lecture' us that the topic is about moving weight, then talk about dragging it out of the garage. (Well, technically it is moving as you drag it but not what we're talking about)
Yes, like you say, a low CG is only one factor in handling, but it's a BIG factor.
Take a touring BMW boxer and compare it against a touring Harley of equal size and weight and the BMW will run rings around the Harley if the rider has any meaningful experience. The Harley will feel heavier and slower. And yes, I've personally owned both and also ridden both on the police force.
