Stromrider wrote:
Wolfeboats, checking the spark plug lead a good idea.
Difference between decending a hill with the throttle closed but engine switched on, and decending a hill with the kill switch off is that the spark plug will not keep itself clean with the kill switch in the 'off' position. With the spark plug 'igniting' with each rotation of the crank at least twice (you get a dead spark too), it does keep the electrodes clear. It is usually only small amounts of oil that will contaminate the electrodes on the plug, but this can build up if the period of travel downhill is prolonged with a dead engine. With the engine on but closed throttle the plug is sparking at very high voltage at around 25,000-30,000 volts, more than enough to keep the electrodes clean.
It's fine to kill the engine with the kill switch if you are stationary/parking but not best regular practice as you may forget to turn off the ignition. Same with side stand, it's ok but remember to switch off the ignition.
Also, the throttle being closed does allow a small amount of fuel in, enough for the bike to idle.
Wolfeboats wrote:
PS:. Motorcycle safety courses teach riders to always use the kill switch to turn off motor so they have the muscle memory to do it in an emergency.
Only in the US for some unfathomable reason - in the UK instructors emphasise it's for emergency use only. It's all to easy to forget to turn the key off or to remove the key if you use the kill switch to turn off on a regular basis. There have been loads of posts on MV of people forgetting to turn off the ignition with drained batteries, burnt headlight lenses having hung their jacket over the front and even stolen bikes on occasion.
The muscle memory theory makes no sense - the emergency is almost always when a bike's gone down with the engine still running. No hands on the bars in this instance - but the red kill switch should be reachable by any passer-by even when the ignition key location or operation isn't known.
Hirers of scooters in Europe often (naughtily) bypass the kill-switch, as without this they get far too many cries for help when the bike won't start.
