Vespa P125X, Stella 2T
Hello All,
I am new and have been lurking for a while and I have just purchased a 1980 Vespa p125x. It it mostly a project but I think it will be fun. So my newbie question is what parts are needed to finish the fuel petcock? I have attached a photo to help.
I have a Stella 2t that I just love and was thinking that most of the parts are the same but there is a plate missing on the Vespa.
Bob
More Photos of Vespa
I just thought that you might like to see more photos.
@jimvonbaden avatar
P125x (4KW Hub Motor)
@jimvonbaden avatar
The cleanest way would be to weld in a patch of steel, grind, use a bit of filler for weld marks, drill a new hole for the rod, and paint. This would only be practical if you're going to restore the frame. Otherwise, that kit would be the easiest way, and it looks fine.
@hibbert avatar
Vespa
@hibbert avatar
Vespa
I like the flames
@rowdyc avatar
@rowdyc avatar
Another option:
Do you have access to a 3D printer. If so, do or get this and no other parts are needed. I have one as a spare.
https://www.thingiverse.com/thing:130324
Or you can try to find the original but for some reason, people want more then what they are worth especially since the original plastic one will prob break eventually.
hibbert wrote:
I like the flames
That and the crash bars were the primary reason I purchased it.
Does it hold up well?
My local library has a 3d printer for the public to use. Does it take a lot of time?
@rowdyc avatar
@rowdyc avatar
The 3D print version will hold up as much as the original plastic one because it's plastic turning the metal rod at the T. Eventually the metal will strip the plastic.
For long term replace with older version like mentioned above.
@geeklion avatar
The Dude
The Dude
@geeklion avatar
[quote="rowdyc"]
I second! the plastic one will break. Old style w/ plate is clean look, and will last.
@geeklion avatar
The Dude
The Dude
@geeklion avatar
The 3d print version would be kinda interesting if machined from aluminum...
parallelogramerist
parallelogramerist
I think you and I would get along just fine.
New Petcock
Here is the new kit installed on my Vespa. Thanks for all the help.
[ Time: 0.0206s ][ Queries: 4 (0.0106s) ][ live ][ 318 ][ ThingOne ]
