2006 Vespa 250 GTS ie
Was riding this afternoon, Vespa started up fine. Parked it and went back to start it again and it didn't start. Battery is fully charged. I don't hear the engine trying to turn over. I don't hear anything. Engine light comes on but then turns off. Have any idea what the problem is?
@tom_jones avatar
Vespa GTS 150 3v SUPER. Vespa V100 x 1. Lambretta Li150 x 1. Px 125 x 2. Px 200 x 1 (red bull special) T5 Classic x 1. Vespa Cosa x 2.CF moto 650mt
@tom_jones avatar
Re: 2006 Vespa 250 GTSie wont start
If you cant hear anything once the key is turned then that means your fuel pump has stopped working. The noise you normally hear when you turn the ignition ikey s exactly that. The fuel pump.
Do you know what that usually costs to replace??
@tom_jones avatar
@tom_jones avatar
No idea buddy. Sorry.
@wbdvt avatar
@wbdvt avatar
rcorn - I had to replace the fuel pump on my 2006 GTS 250 and it was around $200. The fun part is dropping the tank to get it out. Of course, the fuel line plastic connectors snapped when trying to pull them out from the fuel pump. It was a 3 week lead time to get one of the fuel lines.
There are youtube videos on how to replace fuel pumps.
There was recall on the fuel pumps so you should check to see if your scooter is in that recall.
I doubt it's the fuel pump - even without the fuel pump working the engine should turn over.
First port of call - check the kill switch!
Then check the battery connections are tight.
Then check all fuses - not just by eyeballing but with a meter.
If that all seems good:
Check the brake lights come on when you pull in each brake lever.
Listen for a 'click' from the starter relay under the seat.
Report back and we can go from there.
@jkj-fz6 avatar
@jkj-fz6 avatar
Let's clarify "engine trying to turn over". Do you mean you don't hear the starter motor running? Or the starter turns the engine over but the engine doesn't start? Listen for the fainter sounds: Do you hear the fuel pump whirring when you turn the key to ON but before you push the START button? Can you hear the starter relay click when you push START?
Is your kill switch in the RUN position? Does the brake light come on when you pull either brake lever?
Lots of things to check before you replace the fuel pump.
@jkj-fz6 avatar
@jkj-fz6 avatar
jimc, you beat me to it...again! 8)
@harbinger avatar
@harbinger avatar
I'm going to have to go with kill switch as well. If you never use it sometimes you forget it's there and is just this red button by the right bar.
[ Time: 0.0122s ][ Queries: 3 (0.0020s) ][ live ][ 343 ][ ThingOne ]
