worrywort wrote:
Hello. Try this. With engine off roll forward and hold the clutch lever in, engage first gear and see if the clutch frees up after a couple of feet. A downhill slope makes this easier to do.
If my scooter has been left overnight or longer I do the above. The clutch always sticks but after doing this no more problems for the rest of the day. I assume it's because the oil is thick and sticky. I use the straight SAE 50 as sold in every scooter shop.
Tried the above and It seems ok - no sticky as far as I can tell.
Also checked the adjustment and it seems fine - right up against the arm and when pulling in the clutch it seems to be moving the arm easily and with good travel
