Thankfully, Jimc was able to provide the 2015 wiring diagram at:
jimc wrote:
2015 300 wiring diagram now at:
https://manuals.wotmeworry.org.uk/Vespa/GTS300-2015-ABS/
Does anyone have a color wiring diagram? Or a color copy of just the starting wiring?
Should I be testing voltage at specific points in the starting circuit? For example, should I test the voltage at each point in and out of the starter relay? How about voltage at the starter itself? If so, what should the voltages be at specific points?
Or, am I just looking for continuity in the starting circuit at different points? I feel like I have continuity, at times, but the voltage coming across isn't enough to power the starter.
Where are the ground points on the 2015 GTS300? The grounds mentioned in the manual don't seem to correspond with the locations on the scooter itself.
Finally, if I do need to replace wiring, what should I use for wiring and connectors? Is there a specific brand someone can recommend? Is there a kit that has different gauge wiring and connectors? I already need to replace at least one connector, having banged it up pretty severely in my attempts to "fix" the scooter.
Thanks again.
