@berto avatar
@berto avatar
I was riding in heavy rain for about 20 minutes today. When I later opened by top box, I was very surprised to see some water in there!
It's hard to tell, but from the drips inside the box I think water trickled in at the clamshell seam towards the front left of bike. I guess the gasket isn't sealing properly. Has anyone had this problem before? I searched on MV, but this doesn't seem to be a common problem.
Does anyone know if the gasket is replaceable? The gasket does not appear to be cracked or split. But it's over 10 years old, so I wouldn't be surprised if it's hardened and not sealing great anymore.
Demand your money back!
If for some reason that fails then search for adhesive gasket strip on ebay etc. Saying that though, I don't think either of the top boxes I have have any sort of gasket.
@web-tech avatar
@web-tech avatar
The GIVI has a gasket, I just checked mine.
Might try buying some silicone Paste, get some on a rag and wipe the gasket down.
@nightwing avatar
Contributor
2007 LX 150 (memories)
Contributor
@nightwing avatar
The OEM Vespa top box I had on my 2007 LX150 had a tubular gasket in the clam shell joint.
@cdwise avatar
GTS 300, Buddy 125
@cdwise avatar
GTS 300, Buddy 125
Both our Givi and Piaggio OEM cases have a gasket. I had to reattach one of them.
@berto avatar
@berto avatar
Thanks all. Sorry, I should have mentioned that I have an OEM Vespa topcase.
I will look at the gasket more carefully. It doesn't seem anyone's had to replace one before. Or had leaking problems in their topcase.
@web-tech avatar
@web-tech avatar
Try silicone paste, it will most likely stop the leaking in hard rain.
Great for the door and trunk seals on cars.
@berto avatar
@berto avatar
OK, I will look for this at my hardware store or online. Thanks for the suggestion!
@miguel avatar
@miguel avatar
See if you can find o-ring grease. Lots on amazon
But you should also make sure the topcase isn't twisted preventing the top and bottom from mating properly.
Miguel
Best Miguel
@web-tech avatar
@web-tech avatar
Miguel
Best Miguel
Wouldn't o-ring grease be silicone? Don't want a petroleum product, I know that.
"Super Lube 56204 O-Ring Silicone Lubricant, Clear"
@miguel avatar
@miguel avatar
Miguel
Best Miguel
I think so. Is that the same as silicon paste? The product I use is a clear grease with vaseline jelly consistency.
Miguel
@web-tech avatar
@web-tech avatar
Miguel[/quote]
Yep silicone paste.
@berto avatar
@berto avatar
Yikes! Why is the stuff so expensive? I'm sure a tube will last years, but still seems steep at like $50 (CAD) for 8 Oz. The price of dry gear, I guess.
@david_masse avatar
@david_masse avatar
Berto I PM'ed you. I have the gasket you need, yours for free.
@miguel avatar
@miguel avatar
Many under $10 on Amazon.
Best
Miguel
[ Time: 0.0164s ][ Queries: 3 (0.0063s) ][ live ][ 318 ][ ThingOne ]
