On the used 2009 GTS I recently bought, the rear disc had cracking and seemed to have a high spot when the tire spun almost all the way around. I bought new rims (13") with new tire, replaced the disc brake and bought a new caliper with new brakes included. Brakes were really tight on install so I sanded the brake pads a little and everything seemed fine.
Well after about 100 miles, the rear disc seems to have developed that high spot again, where the wheel rotates freely until it hits that spot. If I go for a spin without using the rear brake, both the caliper and disc are very hot to the touch?
Other then maybe replacing the hub or the hardware spacers that hold the wheel on, I am unsure how to fix?
Any recommendations would be appreciated.
