turdzi wrote:
Hello guys,
Need some basic advice for setting up mixture for 2 stroke.
My first suggestion would be to put it back the way it was. Unless you have a fair amount of experience tuning, randomly changing things is going to lead to nothing but trouble.
Having said that, if it is hard to start and won't acelerate when cold, almost certainly lean at idle. So need a bigger idle jet. If you are looking for performance, the idle jet should be rich to the point of almost losing revs, so transition to acceleration has enough fuel.
Not wanting to start when hot means that more fuel is being added than needed. This may just be the carb is overheating when sitting still and the float bowl is boiling. It might be a leaking float valve, flooding the engine. If your carb has some sort of auto-choke, possible it is engaging even when the engine is warm, which it probably shouldn't do.
In general 2-strokes are happiest, provide the most power, and run coolest when they are jetted on the rich side. Horrible for emissions and fuel economy, of course. When messing with jetting, better to err on the side of being rich. If you do not already have one, a fine-wire-electode spark plug will usually work better with uncertain mixture control.
Again, unless you have experience, or are willing to spend time and money learning, refer to paragraph one.
