GTS250e
GTS250e
Are the Vacuum and Fuel lines the same size, and if so, the same quality lines. What size, and quality, do I buy to replace them?
If this doesn't fix my occasionally (after 5 miles or so) stalling scooter, do you recommend that I replace the fuel pump next?
Thanks,
Tom Allen
@starreem avatar
@starreem avatar
What year is your GTS?
Vacuum lines are not fuel resistant. Both fuel and vacuum lines are sized on the inside diameter. You need a thicker walled tubing for either one if you are making any tight bends or turns.
GTS250e
GTS250e
LS50 Vacuum and Fuel Lines
I have a 2007 GTS250ie, but my question was about my 2007 LX50. Thanks for the answer.
@franknbrew avatar
2006 LX 50
@franknbrew avatar
2006 LX 50
Re: LS50 Vacuum and Fuel Lines
I cut off a small piece of the fuel line and visited my local power equipment dealer. I bought 6 feet of the clear ethanol resistant fuel line. The clear line works great to quickly determine that there's fuel where it should be, and not where it doesn't belong.
Does the scooter immediately restart when it stall outs? If so, it's fuel related, and the lines are a great start. If it dies and does not restart until sitting for a bit, replace the CDI.
https://scooterpartsco.com/vespa/lx-50/lx-50-performance/cdi-coil-for-vespa-lx-50-piaggio-fly-50-2v-unrestricted?zenid=f38e4c8be84297ad0dd4c1da5f7fdcf3
GTS250e
GTS250e
It will restart after sitting a while. I guess I need the CDI.
Thanks,
Tom
[ Time: 0.0086s ][ Queries: 3 (0.0016s) ][ live ][ 319 ][ ThingOne ]
