@ellingwoodj avatar
GTS250
@ellingwoodj avatar
GTS250
When I accelerate from a stop quickly, I am getting a new shutter and thud that seems to be the roller weights grabbing the belt suddenly. If i accelerate very slowly from stop I can avoid this harshness that feels like the belt is suddenly getting grabbed. The sound it makes when it grabs does not sound good.
This belt was installed 4 months (2000) miles ago along with new roller weights at a scooter shop that has a qualified mechanic. The belt and weights are all Vespa OEM so I would not expect to have this so soon. 2008 GTS250
Any ideas what is wrong?
@madison_sully avatar
Could be the belt shredding, or a few other things.
All of which should be clear when you open the transmission case.
@miguel avatar
@miguel avatar
It is a common symptom of having to debris build up on the clutch bell housing. The fix is to take it off and scuff it with 220 sandpaper. The bell housing is one of the first things you remove when you access the transmission. I scuff it up everytime I access the transmission, regardless if its been shuddering or not. BTW, the one thing my 2009 GTV doesn't do is "thud" so I'm not sure if your symptoms exactly match mine.
Best
Miguel
@little_karl avatar
2023 Vespa GTS 300 Super
@little_karl avatar
"Shutter and Thud" sounds like a good band name!
[ Time: 0.0086s ][ Queries: 3 (0.0016s) ][ live ][ 318 ][ ThingOne ]
