Do you think the GTS will have a lot more power with the new motor in 2020?
Would it be worth to upgrade my 2018 Gts?
Thanks Older Guy
Would it be worth to upgrade my 2018 Gts? Thanks Older Guy |
Posts: 1477 Location: Cheshire, England, UK. Still European |
All the reports I've heard are saying the HPE engines have a noticeable power increase over previous models. Official figures are 12% in power output and 18% increase in torque. Why not arrange a test ride to see if that's worth upgrading to?
When dyno tested back to back, the HPE had slightly more power than the previous model but the restrictor kicked in earlier cutting a fair chunk off the top speed.
Posts: 13497 Location: Oregon City, OR |
Sure, go test ride an HPE somewhere and see. I'm betting, however, that you won't notice a very dramatic difference. It is basically the same engine after all.
Posts: 8508 Location: Toronto |
Dooglas wrote: Sure, go test ride an HPE somewhere and see. I'm betting, however, that you won't notice a very dramatic difference. It is basically the same engine after all. |
2007 Vespa GTS250ie 2007 Buddy 125 Series Italia 2012 Ural Gear-Up
Posts: 600 Location: Woodland Hills, CA |
Tazio wrote: My 2007 Vespa GTS250 is faster than my 2012 Ural. Hell, my 125cc is faster than my Ural. |
I rode a2019 and 2020 back to back and thought the 2020 felt stronger accelerating from 50-65 mph.
Honestly though if I owned a 2018 I don't think the increased power would justify the extra maybe $3000 to trade up. My 2020 rev limiter kicks in at 82 (indicated) mph, 75 true mph. Isn't that the same as the older bikes? |
Wolfeboats wrote: My 2020 rev limiter kicks in at 82 (indicated) mph, 75 true mph. Isn't that the same as the older bikes? |
2372ighost wrote: Tazio wrote: My 2007 Vespa GTS250 is faster than my 2012 Ural. Hell, my 125cc is faster than my Ural. |
2006 Vespa GTS250ie, 2005 Vespa ET4, 2022 Royal Enfield Himalayan, 2001 Kawasaki W650, 2023 Honda Trail 125.
Posts: 2459 Location: Central Pennsylvania |
Without some serious modifications I can't imagine wanting my Vespa GTS250 to go any faster than it already does. At 75mph it's approaching a stability concern for me because of how light it is. If it could cruise at 85mph that would be disconcerting.
And it accelerates fine already. What's the attraction of a faster Vespa in its current structural form rather than considering something built around a more powerful engine?
Positive
VESPAsfw3 wrote: What's the attraction of a faster Vespa in its current structural form rather than considering something built around a more powerful engine? |
Re: Vespa 2020
Older Guy wrote: Do you think the GTS will have a lot more power with the new motor in 2020? Would it be worth to upgrade my 2018 Gts? Thanks Older Guy https://youtu.be/eo28XcH_pxk DPR |
Losing a little top speed on the new ones is a bummer. But as already mentioned, if you plan to spend loads of time at 80 mph, maybe a Vespa isn't the best choice.
The new one is quicker everywhere in terms of roll-on, which is where it counts around town. |
