et4 125
et4 125
Hi there, im sure someone has a quick answer but i cannot for the life of me find an answer,
looking for the cam timing marks for my et4 125. i dont seem to have any marks or arrows on the flywheel fan or casing.
ive got the 2v mark lined up on the cam but there are no obvious mark for the flywheel arrow.
if anyone could help that would be great thanks.
et4 125
et4 125
this is the only info ive managed to find, if i line up the flywheel on this mark the 2v mark is out by half a tooth so i cant get it on the marks
⬆️    About 4 years elapsed    ⬇️
@technomama avatar
Vespa et4 leadier 125, Vespa Lx 50 2t
@technomama avatar
I've got the same problem, the ignition was set too early now made it too late as a better solution out of worse. Did you get solved that somehow? The easiest way would be to move the pick pick-up, but this doesn't seem to be within design plans.
2007 LX150 2015 GTS (running like a charm!) 2017 BV 350
Umm, considering that there's been a 4 year gap and the OP has only posted twice-on this thread, an no one else, you're not likely going to get an answer from them. Probably better to start a fresh post next time.
[ Time: 0.0099s ][ Queries: 4 (0.0031s) ][ live ][ 318 ][ ThingOne ]
