Hi!
Last week, I picked up a 2008 Stella 2T with 600-some-odd miles on it. ($1000-pretty good deal, even) Runs OK, but it's sat a while. Not my first motorpickle, but my first scooter, so I'm figuring out the intricacies of LML stuff.
A few questions for you all:
1.) A lot of the rubber bits had dry-rotted and cracked for sitting for so long-most glaringly, the bellows between the frame and the carb. I ordered a new bellows and boy those things are a pain to install. What's the best way to put that on? Pull the tank and reach inside?
2.) On the topic of pulling the tank, in looking for a way to install the bellows, I removed the tank to discover a small pool of oil collecting in the flat bit of the frame, next to the oil indicator. Provided it's (hopefully) not the tank itself, where are the achilles heels of the oil system? Which gaskets would be most likely to dry-rot and leak over the course of a decade or so?
3.) Most of the rubber is in not-that-hot shape. Excepting the tires (already on the list), what are the most valuable, necessary rubber bits to replace?
Thanks!
