2007 LX 150 Vespa
2007 LX 150 Vespa
Hello, I wanted to ask for a bit of help. So I have the 2007 Vespa LX 150. Looks like I have a similar issue. Starts right up, If you slowly give throttle to full it will accelerate no problem and go normal.. but if you quickly give full gas, it lags for a second or two and then accelerates quickly. It will almost stall out if you don't let off. I started taking apart the carb, but I wanted some insight first if possible.
Thank you,
@cosmos avatar
2009 LX 150, 2024 GTS Super
@cosmos avatar
I had that problem, caused by a tear in the carburetor piston diaphragm. Easily checked and replaced without even removing the carburetor if it's damaged.
Bill
2007 LX 150 Vespa
2007 LX 150 Vespa
Thank you . I did look at it, but I'm going to check again. I appreciate the help.
@cosmos avatar
@cosmos avatar
Here was my issue/ post/ resolution.
LX150 struggles to accelerate
Bill
2007 LX 150 Vespa
2007 LX 150 Vespa
Very nice... thanks for the info... I'm on it.
@cosmos avatar
@cosmos avatar
One more thing: if you decide to rebuild your carb, check out this video first. Lots of tips apply to your LX150.
Bill
[ Time: 0.0093s ][ Queries: 4 (0.0021s) ][ live ][ 318 ][ ThingOne ]
