2020 Vespa GTS300HPE
Am I losing my mind ? I've popped the left knee cover off 3 times trying to find the alarm interface plug so that I can tap into the plug for 12VDC switched power. I have seen pictures on earlier GTS models where the connector is right there in plain sight, or tucked down slightly away. Has there been a change in which the plug was relocated, eliminated, or revised ? Thanks
@wolfeboats avatar
2020 GTS 300 HPE
@wolfeboats avatar
2020 GTS 300 HPE
The alarm plug is right where it always was. What's different is the plastic leg shield doesn't have an access hole, just slots outlining the hole.
Robot has a video showing using a knife cutting between the slots to create the access hole.
I cut the panel out weeks ago, still not seeing the plug........
@mingo avatar
GTS310 SuperSport
@mingo avatar
GTS310 SuperSport
If you find it, please let us know and post a pic if you can, as I'm interested in moving over my plug'n'play alarm interface plug from my current GTS to HPE GTS.
@wolfeboats avatar
2020 GTS 300 HPE
@wolfeboats avatar
2020 GTS 300 HPE
Mine (also 2020 HPE) was 2-3" below cutout.
If it is the big white round connector, then I see it..... I was expecting a rectangular connector about the same size as the alarm interface adaptor plug ?
@lebo avatar
@lebo avatar
They have been round for a few years
@mingo avatar
GTS310 SuperSport
@mingo avatar
GTS310 SuperSport
Are you able to post a pic of its location? Thanks.
⬆️    About 27 days elapsed    ⬇️
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
Alarm and GTS 300 HPE
Websites currently list the alarm sold by Piaggio as not fitting any ABS models.
Since there still is an alarm connector, which alarm does fit a modern Vespa with ABS (i.e. the GTS 300 HPE)?
Living in NYC, I have no illusions that an alarm will hinder anyone determined to steal a Vespa, though at least it might alarm me and be part of a security system.
@safis avatar
@safis avatar
Piaggio has given us the following part codes for the HPE. I assume they're universal...
Alarm: 1D001770
Wiring: 1D001795
@giallo avatar
GTS 300 hpe
@giallo avatar
GTS 300 hpe
Alarm: 1D001770
Wiring: 1D001795
Thank you! The info available online didn't seem very clear to me
@af1_racing avatar
Sponsor
Sponsor
@af1_racing avatar
the part numbers posted above are correct.
@rallygeek avatar
@rallygeek avatar
Yes the alarm connector on the abs and hpe models is harder to find, the round one isn't in the same place as the earlier models. On mine it was taped and clamped just below the horn.
I have just done an install on my 2018 GTS 300 abs and it all installs fine. My wiring set up for the abs seemed to be slightly different from the instructions there was supposed to be an earth wire from abs system to the indicator relay bracket but it wasn't there.
Has anybody got an idea how to get the system into programming mode. The instructions that come with the alarm are badly translated from Italian which makes them hard to follow. It says to turn the alarm off and on 3 times with a 0.5 second gap and it is put into programming mode but I can't get it to work.
Paul
@harbinger avatar
@harbinger avatar
Paul
It is kind of mind blowing that companies the size of Piaggio cannot get localization better. Don't get me wrong they are far from the only ones but still... Both my Ural and BMW manual have a few tiny issues but nothing that matters. A Vespa is a premium scooter and documentation should be properly translated to English from Italian for everything officially Piaggio. Italian accessory manufacturers I can give a pass to but not Piaggio proper.
2020 Vespa GTS Touring 300
If you figure it out let us know.
You might see if your dealer will help - but I can say that mine has refused, and Vespa won't deal with the end user on this. Likely because from what I can tell the alarm unit needs a firmware update they haven't delivered.
For documentation I found it was better going to the Italian and translating that via Google to clear up some of the functional points. However as you have noticed in the USA we can't reliably get into programming mode likely because it doesn't come with the electronic key that's documented - that appears to be needed to enter programming node. For my scooter, I know that it's not referring to the the scooter key or master.
In my experience I wasted alot of money having the dealer install this- because if you ever loose your original alarm fob you won't be able to disable the alarm until you remove the unit from the scooter.
I don't think Piaggio worries much about how their products are used outside of Italy by non-Italians.
@harbinger avatar
@harbinger avatar
That's a bit strange for a publicly traded company.
[ Time: 0.0101s ][ Queries: 3 (0.0034s) ][ live ][ 343 ][ ThingOne ]
