Hi all
So merrily on way to work on 2005 GT200 when under load (uphill or on motorway nearing full throttle) when it starts to "hold back" or "bog down" albeit briefly then fine again then repeated this intermittently.
So various things tried over the course of the last week
Carb off and clean (quick visual check and a blow out with air)
Inlet manifold ok
Pipe put back on underneath of carb that had come loose
Fixed little plunger type jet (one that is actuated by a lever attached to main throttle on rear)
Coil new
Plug new
Ht lead new
Air filter cleaned
More responsive and generally better but problem is still persisting
(Under load i.e. uphill or full throttle on motorway scoot is "bogging down" intermittently?
Any help appreciated
