@alejandro_waspa avatar
Excalibur Gray Granturismo 200L
So I have a Bell Carbon Custom 500 RSD helmet; I think the bubble shield look is great, but I learned the hard way that the design is not friendly to people who wear prescription glasses.
I was thinking of about resigning the 3/4 helmet for both club auto-racing use and if I ever have a passenger. Now I'm on the hunt for a full face, especially with colder weather on the way. I hate the wind noise of the Bullit, and I think the Gringo is just okay in terms of visibility and has no ventilation.
I've searched the forum and a lot of the helmets I found were no longer being produced (like the Arai Condor user Dessita posted about).
Obligatory pic of current lid:
@attila avatar
@attila avatar
Re: Recommend a Retro Full Face, Hard MODE: No Bullit or Gri
If you wear glasses (like me) you must not miss a modular helmet.
Easy to open without first removing it, you can continue to wear it if you have to stop or slow down for a short time.
@miguel avatar
@miguel avatar
Shoei Neotec II helmet is the most quiet of the modular helmets. Schubarth C4 Pro is pretty good as well. The major advantage to the Schubarth is the view port is huge. Both weigh about the same
Interestingly, the Schubarth carbon weighs about the same as the non carbon so I view carbon helmets as a fashion statement, at least wrt to Schubrath.
And to add confusion to clarity, see here: https://www.webbikeworld.com/motorcycle-helmet-reviews/
Best
Miguel
@attila avatar
@attila avatar
Perfect Miguel, my modular is indeed a Schubert but in ABS (less expensive, I'm stingy ... mea culpa).
@miguel avatar
@miguel avatar
Me too. I think the carbon is unnecessary. Miguel
@25bikez avatar
2022 Liberty 150S-"Meg"-SOLD
@25bikez avatar
I have a Bell 500 with a bubble shield also. I have a pair of glasses with smaller lenses and a narrower frame I wear with it.
My normal frames fit just fine under my HJC CL-Max modular.
Do you put the bubble shield on after your glasses?
@rrider avatar
@rrider avatar
AGV Legends is a well known, if a bit pricy retro... I have no personal experience though.
@bob_copeland avatar
Modular Flip Open - My Choice
The full face helmet must be a safer alternative. They just are
to claustrophobic for me. I love the modular flip up. Mine has
enough room for glasses.
I wear a lite cotton helmet liner (durag). I put my prescription sun
glasses on, put on the durag that covers the ears - allowing the
helmet to easily slip on without disturbing the glasses.
Bob Copeland
Minni-so-cold 37 degrees today
@max6201 avatar
GTS 250, LX 50, and Falcon 200
@max6201 avatar
Re: Modular Flip Open - My Choice
Bob Copeland
Bob! It must be that cold in your state. I have seen that helmet before. I definitely need to get one like that myself soon.
@25bikez avatar
@25bikez avatar
I put my helmet on first, then my glasses. My Bell 500 shield is not the classic 3 snap bubble, though-it flips up.
@caschnd1 avatar
Grumpy Biker
Grumpy Biker
@caschnd1 avatar
Well, if you eliminate the Bullit and the Gringo from the mix, that's probably about 95% of retro full face sales in the USA.
There are a few others...
The Torco T1 at around $200. The Ruby, probably $1000+. The AGV, mentioned above.
-Craig
Torco T1
Torco T1
Ruby (carbon fiber and very pricey)
@captain_jim avatar
2020 GTS 300 HPE
@captain_jim avatar
2020 GTS 300 HPE
Check out the Nolan N70-2 GT helmet. It is not retro, but I have found it to be the most comfortable helmet I've owned. It uses a removable chin-bar, allowing the helmet to be a 3/4 or have the protection of a full face, but with a much larger than typical view.
Mine is in white...
Plenty of room for glasses.
BV 350
BV 350
I wonder
Have there been tests of the protection of the flip-up modulars in relation to actual full-face helmets? Hard to believe that the hinge mechanism/chin bar is strong enough to resist failing under the impact of a crash. I've been tempted to get one of the modulars, but have my doubts as to the protection. Since the left-turn-SMIDSY accident scenario is pretty common locally, and is nearly a head-on crash, definitely concerned about facial protection.
So I wear a full-face. Not that burdensome to take off the glasses, put on the helmet, put on the glasses. Flipping up the shield at stops seems to be enough as well.
@mayorofnow avatar
2020 GTS 300 HPE
@mayorofnow avatar
2020 GTS 300 HPE
If I was in the market for a modular helmet, the first one I'd look at would be AGV. Its chin bar survives 97% of crashes:
https://sharp.dft.gov.uk/helmets/agv-sport-modular/
Shoei only survives 70%:
https://sharp.dft.gov.uk/helmets/shoei-neotec-ii/
That's 10x as many failures, and the temple does a worse job absorbing shock.
@25bikez avatar
@25bikez avatar
Mine is in white...
How noisy is it with the chin bar installed? My biggest complaint about my HJC CL-Max modular is that it's noisy at highway speeds.
@captain_jim avatar
2020 GTS 300 HPE
@captain_jim avatar
2020 GTS 300 HPE
25BIKEZ wrote:
Mine is in white...
It is quieter than the HJC 3/4 or the Bilt modular helmets I have. With the chin bar installed (takes about 2 seconds) it is much quieter than without. The loudest thing I hear while on my GTS is the wind when the vent on the front shield is open - close that vent and the noise level really drops. So, a trade-off of getting cool air or quiet. If it is cool enough out, I keep that vent closed. The other 3 vents on top add some wind noise when open, but not as much as that vent on the face shield. It is warm where we live, so that vent is really appreciated.
I have a Laminar Lip on the Faco mid-height windshield on my GTS, and that made a very significant difference in the noise level.
@25bikez avatar
@25bikez avatar
Captain Jim wrote:
25BIKEZ wrote:
Mine is in white...
Thanks. I'll have to give that model a try to see if it fits my melon head.
@bazziemoto avatar
1974 Vespa 125 Primavera, 1980 Bajaj Chetak, 1962 Lambretta 175TV3, 2006 Yamaha Vino
@bazziemoto avatar
You can buy a combination visor/flip shield for the Custom 500. I don't wear my 3/4 much anymore, but this shield is rad.
[ Time: 0.0292s ][ Queries: 4 (0.0149s) ][ live ][ 313 ][ ThingOne ]
