2007 Vespa LX 150
2007 Vespa LX 150
I need some guidance, I just recently purchased my first Vespa My turning signals are not working at all. What are some things I can try from least expensive to more involved?
@bob_copeland avatar
Electrical Stuff Can Be Complicated
Go to a dealer and have them fix it. If it has problems
later you can go back.
Disclaimer: I have no mechanical experience - even less with electrical matters.
Hats off to all you who can fix these things.
Bob Copeland
Frost Bite Falls Minnesota
@jkj-fz6 avatar
@jkj-fz6 avatar
Bob, you'd go to the dealer to have them show you how to put the key in the ignition. Razz emoticon
First check the fuses, then the turn signal switch. Vespa switches go bad fairly regularly.
If you need help to find the fuse and get to the switch one of the LX guys will be around to tell you how.
Good luck! 8)
2007 Vespa LX 150
2007 Vespa LX 150
Thanks for the suggestions. Yes please, I know where some of the fuses are but not sure which one is for the turn signals. So if anyone can help with where to locate that fuse...
@miguel avatar
@miguel avatar
You have the manual. The fuse locations should be in there. The manuals are available in the Wiki page, accessed via the tab in the upper left corner of this page. You can probably find it online as well.
Best
Miguel
@fudmucker avatar
@fudmucker avatar
Re: Electrical Stuff Can Be Complicated
Bob Copeland
Bob, my bike has a screen just like yours and I found some serious buffeting taking place. I sourced a used pair of touring screen brackets and lifted the screen until I could fit my hand between the headlamp and the underside of the screen. I found the buffeting substantially reduced.
Use it... lose it.
Just sharing.
@vespergeezer avatar
GTS300, Cosa LX200
GTS300, Cosa LX200
Re which fuse
... just pull one out in turn and look for a break in the wire.
You should carry a couple of spare fuses in with your on board tool kit.
@harbinger avatar
@harbinger avatar
Turn signals are for pussies, just use hand signals like a real man.
OK I'm kidding, the advice here is pretty solid. Fortunately at least hand signals are legal so you can get by until it's fixed.
@attila avatar
@attila avatar
In Italy, on some dangerous crossroads, a lot of scooter riders (me too) stretch out of the arm even if the direction indicators work ... you never know.
Windscreen Height
Fud,
I wonder if you are taller than I am? I am 5'9". I do not
notice as much wind bracketing.
Best to you from Minnesota.
Bob Copeland
@attila avatar
@attila avatar
I am 1.86 meters tall and I weigh 130 kilograms and my waist circumference is 1.5 meters...Oh I know ... I'm a little obese, I like to eat if you haven't understood. Crying or Very sad emoticon
So to stay on topic, I point out my "important" dimensions that because of them prevent other drivers, a good view of my direction indicators.
@harbinger avatar
@harbinger avatar
So more Attila the Hut than Attila the Hun?
Just playing with you and sorry it's a cultural reference you probably won't get. Though I imagine classic like Spaceballs must have an Italian dub or at least subtitles...
@attila avatar
@attila avatar
In my DVD library I have many films (more than 1000) and many of Mel Brooks, my favorite is Frankenstein junior.
@harbinger avatar
@harbinger avatar
Nice! Yeah Young Frankenstein is high up on my list as well.
GT 2.4
GT 2.4
What's a DVD?
BV 350
BV 350
logical mind
If you have a logical mind and some mechanical capability, fixing the problem yourself should be possible. On the other hand, if you have no experience with electrical repair or mechanical work, you may succeed in disabling your scooter entirely, and running up a bigger bill at the dealer for them to correct your mistakes. If you've had success repairing other things, there's nothing particularly tough about working on scooters. If you've never fixed a single thing in your life, perhaps now is not the time to start. If it is not the fuse (be sure you are looking at the right one) it is probably time to take it to the dealer.
@attila avatar
@attila avatar
Motovista wrote:
What's a DVD?
It is a silver-colored plastic disk on one side but it is not a U.F.O.
Science fiction, fantasy and war.
@pinkscooter avatar
@pinkscooter avatar
DVD's are my favorite coaster, no damaged tables here.
@lostboater avatar
@lostboater avatar
Dudes,
Let's get back to the original problem and take the horse play to the yard.. The guy needs our help.
@jkj-fz6 avatar
@jkj-fz6 avatar
lostboater wrote:
Dudes,
Yeah, and let's hope the OP gets back with some feedback...whether it's fixed or not.
@attila avatar
@attila avatar
Yes...it's right, could be the light turn relay or...on Italian forums, widespread oxidation on contacts is also reported.
Sorry for OT.
@larrymk avatar
Vespa Super 300
@larrymk avatar
Vespa Super 300
I have a 2012 Vespa 300 super, a few years after getting it my turn signal light went out so I replaced all of my turn signal lights with LED lights from Scooterwest as I thought they would last a long time and riding without turn signals is not fun, so far has been great. They have the kits and videos on how to install them, not a big deal. I have also burned out fuses on other things and it is quite easy to check your fuses and replace if bad. Hope this helps, congrats on your new scooter and ride safely.
Larry
[ Time: 0.0207s ][ Queries: 4 (0.0091s) ][ live ][ 313 ][ ThingOne ]
