To check the oil, go to this video, skip to 6:43.He just changed the oil and is checking the level. The oil dip stick is on the left side of the bike, just in front of the rear wheel. You'll see it. Do you have oil on the dip stick? If so that's good. If not, that could mean bad.Oil lubricates the engine parts. Without oil, the friction between the part is pretty high and will heat up quickly. When it gets too hot, some of the parts begin to warp and can cause severe, perhaps fatal damage to the engine.
Do your lights some on when you turn the key to on? If no, you have an electrical problem. When you say, the engine won't start, does it sound like its cranking and turning and just not catching or not cranking at all. I'd stop trying to start the bike till you get a little further down the trroubleshooting path.
Also, when you turn the key to the on position and before hitting the starter button, do you hear a quiet hum for about 1 second? That's the fuel pump. If you don't hear that, then there's something wrong with the fuel system. You do have gas in the tank, right?
Miguel
⚠️ Last edited by Miguel on UTC; edited 1 time
