everytimeidom wrote:
Not that you need the plastic panels off to do this, but I get great use out of the dual USB power panel that replaces the stock left kneepad. It connects to one of the existing plugs just inside that opening. I use one to charge my phone and the other to charge my GoPro.
Installing/routing a battery tender lead might be something to look into while you have the panels off, depending on how you want to route it.
Yes on both. I purchased the ScooterWest harness plug so I can shop for a power point, and I installed the Battery Tender leads when I put in the new battery. I like to run the lead out the center rear of the battery cover. I make a notch in the cover so it'll sit flat.
Thanks.
