2013 S 150 SE
2013 S 150 SE
I've noticed the past couple of weeks that after I ride for about 15 minutes, from time to time it won't immediately start again. Part of the riding has been near full throttle on a highway so I'm thinking a heat issue? It's never happened to a cold engine. Today it was even a 15 minute break and the temp is only mid 70's and I couldn't get it to start. It's cranking like normal but then it dies. I'm not a mechanic but is there anything I can easily check? It had it's last service just a few months ago so everything is up to date maintenance wise
@sro avatar
@sro avatar
2009 250
What's the milage and have the valves ever been adjusted?
2013 S 150 SE
2013 S 150 SE
It's at 16,000 miles. Unless valve adjustments are part of the standard interval services, they have not been adjusted.
@paddlenround avatar
This could be related to the awful EVAP system in that bike. The EVAP creates a kind of vapor lock when the engine gets hot. It's awful and can get worse over time. Once it's hot, it will stop turning over for a little bit.
FAQ: Why does my GTS groan/moan/moo or fart when off?
Continuous attempts to turn it over should result in it starting but it can take a while. It appears you are in California and this horrible, poorly designed system cannot be removed (legally).
2013 S 150 SE
2013 S 150 SE
One part of me hopes you are right because there is nothing to fix. The other part hopes the EVAP is not the problem because it won't be fixed.
@sro avatar
@sro avatar
2009 250
Part of a standard service is tough to answer. A valve check is usually kind of expensive and most people don't do it. Valve intervals looks to be 3750 and 15k miles for the Lx150 based on the wiki here. Do you have the old service records to see if it was done?
Next time, crack the fuel cap. If there's a big whoosh, you found the answer.
2013 S 150 SE
2013 S 150 SE
I'll have to check the service records when I get home, thanks.
I'll try the same ride again tomorrow to see what happens and then crack the fuel cap. [/quote]
GT 2.4
GT 2.4
This does sound like valves, especially if you've been running an air cooled bike flat out for miles on end.
Or the air/fuel screw in the carburetor is out of adjustment. Seasonal changes in the fuel blend in California can affect carb. scooters more than EFI bikes, and it seems like it's about that time.
/\ /\ THIS.../\ /\
Stromrider wrote:
/\ /\ THIS.../\ /\
Please note that this is a fuel injected version. So...put a little seafoam in it to get started.
@web-tech avatar
@web-tech avatar
Paddlenround wrote:
Stromrider wrote:
/\ /\ THIS.../\ /\
If it is running smooth at idle I don't see what sea foam will do to help.
@sro avatar
@sro avatar
2009 250
[/quote]
What happened? 8)
Vespa GTS 250ie
Vespa GTS 250ie
Fuel pump if this scoot' is of the vintage that Vespa had pump problems...
WEB-Tech wrote:
Paddlenround wrote:
Stromrider wrote:
/\ /\ THIS.../\ /\
Noting that someone said that it might be the valves...putting in seafoam can help clear out the deposits that build up. Personally, I think it's the EVAP but seafoam is good at clearing out gunk and if there is any, running that through the fuel system won't hurt a thing.
My take - it may or may not be the valves, but without checking them you could be chasing your tail for ages and spending money on parts and labour for no benefit.
@sro avatar
@sro avatar
2009 250
If they were never checked with 16k miles, it's about time anyway.
2013 S 150 SE
2013 S 150 SE
Thanks everyone for weighing in. I can't find my last service receipt so I'll have to call the mechanic.
Opening the gas camp yielded nothing. The problem happened Friday on my way home from work on an 85 degree day. I wanted to stop and pick up dinner and just hoped it would start back up. It didn't, so I spent a few minutes in the restaurant parking lot. I found some shade and took out the pet carrier to see if it would help cooling. That did seem to help limit the down time. I was worried a bit though as a few times I tried to start it back up, all I heard was a whirring sound. Once it did start back after leaving it sit for a few minutes, it sounded great again.
This morning I figured there were not going to be any stops on my commute so I decided to ride. It was about 50 degrees and I while on the freeway I remembered I had to go by the post office. I drove at least 55 the whole way. The post office is near the end of the commute and my bike was only off for a minute or two. It started right up.
When this has happened, did you hear the fuel pump prime when you first switched on, before trying to start?
2013 S 150 SE
2013 S 150 SE
Usually I can hear it. This was the first time some of the attempts to start it resulted in no fuel pump sound
@sro avatar
@sro avatar
2009 250
I think you found your problem. This isn't a valve issue.
Hearing the fuel pump when trying to start is irrelevant (the starter's too loud to hear it anyway). It's hearing it prime when you first switch on that's important. If you don't hear that, your fuel pump may have temporarily seized from the heat. 2009/2010 Vespas had a recall for this problem.
Another reason can be that the 'ignition loads relay' has decided to play up. That's another known problem.
[ Time: 0.1884s ][ Queries: 5 (0.1766s) ][ live ][ 313 ][ ThingOne ]
