@dave avatar
2007 GTS 250
@dave avatar
2007 GTS 250
Hi, just yesterday I installed a new Mollosi 17.5 carb on my 70cc ET2.
There is clip retainer that holds down the auto-choke. The one off my Weber carb had to be altered with a Dremel to fit, does anyone know if there is a correct part I can order?
Also does Mollosi make a rubber intake manifold for there carbs and the Vespa?
@jimh avatar
MV Saint
Haud yer wheesh't if ye cannae be nice
MV Saint
@jimh avatar
Hi Dave, Just check out there site mate. Here's a link about your manifold question http://www.malossi.com/Catalogo/Cata_Main.asp?Marca=250&Modello=MO/VEET50&Famiglia=0&CodArt=02%205733B
Cheers ( It's Malossi) Razz emoticon
@bassplayer avatar
'03 ET2 70 & '85 PX150
@bassplayer avatar
hey dave. dont hold yr breath while waiting for responses about an et2.....
the above link didnt work for me, but yes malossi do make a bigger manifold to fit the 17.5mm carb. ive ordered mine from SIP.
what is the rest of your setup and are you going to re-jet your new carb or go with the jets it comes with?
cheers.
@dave avatar
2007 GTS 250
@dave avatar
2007 GTS 250
Yes I have noticed this is kind anti ET2 on this site.
I did get my new carb and it runs great, the only thing that I changed was the needle clips, the little c-clip is in the lowest position cause it was running lean in mid throttle, I didn't change the main jet, its seems to run good as is.
So I think I'm done with major upgrades.
Did you get the manifold? I'll check with SIP today, thanks.
I wish there was a only et2 forum.
@jimh avatar
MV Saint
MV Saint
@jimh avatar
Then there would only be 5 members ROFL emoticon
Goodluck
@bassplayer avatar
@bassplayer avatar
hey dave.
the manifold i ordered is part no. M025733B from sip. http://www.sip-scootershop.com/
they say it gives better performance than opening up the stock one.
we'll soon see
@reido avatar
Pearl/Blue 2001 ET2
@reido avatar
Pearl/Blue 2001 ET2
... Razz emoticon Six!
@dave avatar
2007 GTS 250
@dave avatar
2007 GTS 250
Some day I will own a vintage scoot, but for now I'm having fun with my ET2, what can I say it looks brand new, and I traded a ukulele for it!
@jimh avatar
MV Saint
MV Saint
@jimh avatar
That was a George Formby film, right?
@scooter_west avatar
Sponsor
Sponsor
We have Malossi intake manifolds for ET2s in stock. Unfortuantely they are $62.95, but it's cheaper than you'd get one from SIP for. Their shipping is ridiculous.
@dave avatar
2007 GTS 250
@dave avatar
2007 GTS 250
Max-
Do you sell the c shaped retaining piece that holds down the auto choke for the mollossi 17.5 carbs? I had to cobble one together to get it to fit mine.
Sponsor
Sponsor
dave wrote:
Max-
Sorry, we don't. I'm surprised it didn't come with the carb kit.
@bgk avatar
ET2
@bgk avatar
ET2
So is this for manifolds over 21mm? Because I was fitting a PHBG 19 today and converting from a weber to this carb was no problem. the manifold isn't restricted in any way. Or is it a shorter manifold that no longer uses the standard airbox?
On a side note, Anyone have an idea on jetting for a malossi cast iron kit with a 19mm phbg. No other changes other than the reeds included in the cylinder kit. I have a 72 in it now and it seems to be OK, but there's not much punch over half throttle. I have a fairly fat needle (not much taper) in as well. I'm thinking I may even go back to the weber and just rais the needle as high as it goes.
Sponsor
Sponsor
It is for 12-21mm carbs. It a nice replacement if your original is worn out. It's the number listed above.
@bgk avatar
ET2
@bgk avatar
ET2
Ah, that makes sense. The stock manifold does seem very thin. I could see myself tearing it after several changes.
@cbaker avatar
2006 BV 500, 2004 ET4
@cbaker avatar
Make it 7!
⬆️    About 3 years elapsed    ⬇️
@fabio_dougie avatar
Scooter Pimp
Scooter Pimp
Make it 8 !!
@xantufrog avatar
Moderibbit
Moderibbit
@xantufrog avatar
Eh, it may be another necro post, but what the hell - make it 9!
[ Time: 0.0246s ][ Queries: 4 (0.0146s) ][ live ][ 318 ][ ThingOne ]
