@inkslinger42 avatar
Gimp
'07 GTV , '08 Stella
Gimp
I'm wanting to put a helmet hook onto my lxv. I've got the part, now I need to put it on. Should I drill, punch or just take a hammer to it? I'm going to put it where it would sit on my Rally. if you've done this before, I'd like to know what you did and how you did it. Maybe I'll make a how to out of it when I'm done.
http://www.scooterworks.com/Hook_Helmet_P1208.cfm
@rover_eric avatar
@rover_eric avatar
if you're going to use a vintage-helmet hook, just drill the two holes with the proper sized drill bit. measure and mark the holes first with a sharpie or something.
@rex avatar
Rock Star
Moto Guzzi V7 Classic
Rock Star
@rex avatar
Tanya, be careful about exposing raw metal of the LXV's body to San Francisco's sea mists. I'm not sure if it's going to be a problem but remember, Exposed Metal + Salty Mist = Rust.
EDIT: Even if you drill a hole and screw a screw in it, salty air will find its way into it, especially if the screw is not rust-proof.
Gimp
Gimp
I'm planning to sand any rough spots and then use touch up paint to cover exposed parts.
This is what I would do.
Take the scooter upstars and have Tom do it....
Then buy him lunch....
@spock avatar
2002 ET4 & 1980 100 Sport
@spock avatar
.22 cal ought to make the right sized hole.
@drewteague avatar
@drewteague avatar
Definitely drill, and use plenty of WD-40 so that you don't succeed in merely dulling your bits. Then clean with degreaser and touch up. Should look nice! Don't forget to post pics!
~Drew
@michael_moore avatar
GTS(me)/GTV(wife)
GTS(me)/GTV(wife)
You might want to use a pointy punch to get the bit to start in the right place, and maybe drill a pilot hole first if the hole you're drilling is kinda big.
(Don't ya love it when I talk technical?)
Vespa GT 200
Vespa GT 200
Hi,
If you don't want to buy touch-up paint which may be too old and hard to use the excess later, just dress the drilled hole with some clear Nail Polish - that'll prevent any possible corrosion. Hope this helps...
Happy Motoring!... Jim
@spock avatar
@spock avatar
Nail polish. That's rad. I'd like to meet the tech that came up with that.
@greasy125 avatar
@greasy125 avatar
you've seen the top of my toolbox... lemme tell ya baby, them red and clear bottles ain't for my toes!
nail polish is an old racer's trick.
comes into play where you can't use loctite...
best,
-greasy
2005 GT, 2002 ET4
2005 GT, 2002 ET4
Sure greasy, it's o.k. and a good color for you.
@tikka avatar
07 GTS250ie VCOA#2794
@tikka avatar
But man ... It should be! Just Nasty!
Sorry to go OT Tanya. I just couldn't resist posting that Greasy toe again!
Hey Greasy I hope it's finally healed up. Toes can be a bitch.
2003 ET4, 1972 Primavera
Don't post stuff like that till after lunch.
@kurlygirl avatar
Roller Derby Name: She-Ra, Princess of Pain
@kurlygirl avatar
Hi Tanya! I too have an lxv -- just got it last week. The other day I noticed a small metal hook under the leading edge of my saddle. Someone told me that this was a helmet hook -- i.e. the helmet is locked in place when you close the saddle. Is this a helmet hook? Or is it for something else?
Thanks!
@gaseous_clay avatar
1978 P200E, 1963 GS 160
Thanks!
Can't believe no one mentioned that yet! Unless Inkslinger's looking for something a little more stylish.
[topic6755]
@primordialdancer avatar
Temporarily Scooterless... :(
I can also recommend just dipping the screw threads into some silicone before assembling. The silicone will coat the threads as well as the hole and you can pull off any extra that squeezes out to the side of the screw head after it dries up.
Good luck,
Desi B.
@illnoise avatar
@illnoise avatar
couple things I'm surprised no one mentioned:
1) put a piece of masking tape down where you're going to drill, mark the holes on that, and drill through the tape, it'll help prevent the paint from chipping. Then pull it off very carefully.
2) obviously, use a bit that's smaller than the screw thread, start with a tiny bit to make sure the hole is centered, switch to one smaller than you think you need, then if you can't get the screw to dig in, drill again.
2a) make sure there's no wiring or gas tank or tire on the other side of that metal!
3) if you're worried about rust, paint it with rust inhibitor. If the paint doesn't chip somewhere visible, there's no point in sanding or touch-up paint, the holes will be hidden behind the hook, you just want to prevent rust.
2007 Grey Vespa LXV
2007 Grey Vespa LXV
Gaseous_Clay wrote:
Thanks!
[topic6755]
I have an LXV too (actually I got it after looking at Tanya's at SF Vespa--it was the only one they had on display). I liked the hook on the LX, so was disappointed to discover when I picked it up that the LXV didn't have one. The helmet hook is fine for the helmet or even for grocery bag handles, but (a) you can't get to it unless you open the seat and (b) it's too small/skinny for a handbag or something similar. I'm very curious to find out how Tanya's hook works out because I'd like to get one too.
[ Time: 0.0248s ][ Queries: 5 (0.0125s) ][ live ][ 318 ][ ThingOne ]
