Thanks OlderGuy
⚠️ Last edited by Older Guy on UTC; edited 1 time
My 2018 300 has the muffler pluged by mice. took it off but no way to clear it.Need to buy new one where is the best place to buy one? I dont want to buy used as the scooter only has 900 miles on it and if I buy used I will have to replace it again sooner then later.I forgot to plug the muffler before puting it away for the winter. Can I reuse the chrome shield on the new one?
Thanks OlderGuy ⚠️ Last edited by Older Guy on UTC; edited 1 time
Are you only looking for a factory replacement or aftermarket? I would say check out AF1 for either factory or aftermarket. I'm sure the stock muffler isn't cheap by any means though.
![]() BV400, Primavera 150, Yamaha Zuma 125
Posts: 4508 Location: Twin Cities, Minnesota |
Mufflers aren't cheap. I'd spend some time and effort clearing what you have. I don't think it should be hard to do with the muffler off.
![]() UTC
Posts: 12504 Location: Fond du Lac, Wisconsin |
![]() 2015 GTS 2017 BV 350
![]() UTC
Posts: 5666 Location: Home of the Alamo |
![]() '07 LX150 (Sold), '17 GTS300, '16 BV350, '15 EN650, '09 FXDF (sold). '15 FLSTN
Put the muffler in a tub with several gallons of extra strength white vinegar. Leave at room temperature for about a week, agitating daily. Will eat the mice out of there. When finished, let muffler set in several gallons of warm water with a box or two of baking soda to neutralize the acidity.
I guarantee this will work and will cost about $15 to accomplish. Good luck! |
![]() UTC
Posts: 7674 Location: Madison, Wisconsin |
![]() MP3 500, GTS 250 (both 2008 MY), 2013 Piaggio BV 350, 2014 Can Am Spyder RT
You could also take off the shiny bits and grill it for a couple of hours.
Muffler BBQ.... |
since you have the muffler off try a pressure washer from each end?
I had a mouse nest in a transmission bell housing - turned out to be made of small scraps of paper, grass, and rag - it came out quite easily. |
Johnny Two Tone
![]() '15 GTS300, '86 PX125EFL, '66 VBB, '01 ET4
Posts: 9032 Location: San Diego, CA |
the pressure washer attempt seems like a no brainer - take it to a do it yourself car wash if you don't have one.
I had a Honda Goldwing 1800 a few years back that was kept in a garage. Every spring when I would fire it up, it would spit dozens of acorns out of the pipes. It was funny at first. Then, I learned that rodents like to chew on and nest in the air filter which was accessible only by having to disassemble the whole top end of the bike. Several hours work.
I never looked into it. I let the next owner worry about it. ⚠️ Last edited by NightWing on UTC; edited 1 time
RIP
![]() In garage: Yamaha Tricity 155 Urban 2019 - MV Agusta 125 RS 1956
Posts: 8291 Location: Latina (Italy) |
At the an of the original costs, it is better to buy an after market muffler...it's must beaty,best of original...
The remedy for mice is simple, I have some cats and I put their food in different places such as garages or agricultural vehicles storage. The presence (smell?) of cats can suffice; better females (sterilized), males piss on walls and other objects. |
![]() UTC
Posts: 3807 Location: Minneapolis USA |
![]() 2013 Vespa 300 Super, 2022 Kymco AK 550
Mice in the Exhaust
The problem is quite common. My cat "Jack" kills about a mouse every two months. My house backs up to a forest - everyone has an occasional mouse.
Good luck, Bob Copeland Minnesota |
RIP
... I have two huge cats, a male called Birillo and a norwegian breed female called Grigina ...
interesting dilemma. they do need to come out alive. there are chambers in the muffler. a dead mouse would stink for a very long time??
![]() UTC
jerryd wrote: interesting dilemma. they do need to come out alive. there are chambers in the muffler. a dead mouse would stink for a very long time?? |
![]() UTC
Are you in the tropics? I always put some steel wool at the end of my muffler in the winter.
![]() '20 300GTS Super Tec '09 250 GTSie '75 Rally 200 '79 P200 '09 Stella 221
Posts: 2610 Location: Midway, Kentucky |
Willie B wrote: Take it for a spirited ride and bake them |
Max6200 wrote: Willie B wrote: Take it for a spirited ride and bake them |
RIP
Willie B wrote: Max6200 wrote: Willie B wrote: Take it for a spirited ride and bake them ![]() |
Attila wrote: Willie B wrote: Max6200 wrote: Willie B wrote: Take it for a spirited ride and bake them ![]() |
RIP
Max6200 wrote: Attila wrote: Willie B wrote: Max6200 wrote: Willie B wrote: Take it for a spirited ride and bake them ![]() The other curious thing is that the term "mice", in italian is almost equivalent to word "micio" (kitty in english). |
If it runs OK ride it?
My 1st approach would lean towards a torch flame directed into the tip outlet, or: high pressure air? Water? Poison gas?lay in a fire? shop vacuum? feed them poison? extreme cold? as in water then frozen? poison pellets? How about setting off firecrackers inside the inlet? They like to nest on top of my engine or battery not in the muffler guts. The last thing I'd do is buy another muffler! They are currently eating the engine cover on my new Lincoln unless they are they goodies I left there? |
RIP
Always
I always have a coupe of bait blocks (De-Con, I think) in the garage where I believe rodents might congregate. Have never found dead ones in there, nor evidence of live ones causing problems. Usually put out fresh ones in the fall, when they want to come inside where it is warm. A next-door neighbor had a rodent infestation when she got sloppy with her dog food, but none came to visit. Or at least they went outside to die.
I found that the local hardware store sells rubber crutch/cane tips in various sizes, can be used to plug any exhausts that are large enough for rodents to enter. Just need to remember to take them off in the spring, as it makes it tough to start the bikes. Work equally well for slipping over the outsides, or just jamming into holes. So long as you don't have a catalytic convertor in the muffler, I'd be tempted to fill it with spray oven cleaner, let it work for a while, and flush it out. That stuff seems to dissolve almost everything, except metal. Although, if the obstruction is largely paper and fiber, a propane torch applied to the inlet should work. |
RIP
This old post shows what the inside of the muffler looks like .......without any mouse mods
A look inside the GT muffler : "CRAZY" |
dalemanuk wrote: This old post shows what the inside of the muffler looks like .......without any mouse mods A look inside the GT muffler : "CRAZY" |
Johnny Two Tone
sdjohn wrote: probably because someone revived a 13 year old thread with talk of roadkill |
On 2 strokes, when the muffler gets plugged up with oily crud, the solution is to pour some gas into the muffler, slosh it around a bit, wait a min or so for the fumes to clean, then using a long stick, light it on fire and let it burn till it goes out. Then a few taps with a rubber mallet to loosen the ash and debris, then shake it out. I usually use diesel fuel myself, less tendency to go "BOOM" when you light it off. Does the same thing once you get it burning. I would try that or after removing the chrome trim, setting the muffler in a camp fire/fire pit and letting it burn for awhile. That should turn anything inside that isnt steel into ash, then using the mallet, tap it a bit, shake it out. The remount and go for a "spirited" ride to "blow out" the remains/ash. Replacing, unless your shopping for an aftermarket pipe, would be my last choice. The GT200 I am getting has a pipe, and I may be looking for the stock muffler depending on how my ears like or hate the pipe. I prefer quiet, very quiet over most pipes I have heard. Mike
When I was riding trials, the importer had an adapter that necked the end of a heat gun down to the head pipe size. We would insert this into the muffler, lay the muffler on the ground and turn on the heat gun which did an amazing job of defouling. The muffler would start to smoke and then a flame would start wicking from the end of the muffler. This worked great.
I always
I always thought, if you had a problem with your 2-stroke muffler fouling, you weren't spending enough time at wide-open throttle.
Although I must say, it was a challenge on my YZ490. |
Re: I always
Jimding wrote: I always thought, if you had a problem with your 2-stroke muffler fouling, you weren't spending enough time at wide-open throttle. Although I must say, it was a challenge on my YZ490. |
