Rebuilding a 1984 P200 motor. Running a stock cylinder, but may end up with a kit down the road. Currently have a Scootopia big box pipe. Going to be doing some long distance touring on the current set-up. The person I am riding with is running a 210 malossi, 60mm crank....so he is going to be a bit quicker than me.
My stock crank is in good shape, but I am interested in a 60mm crank to squeeze a bit more out of the otherwise stock set-up.
1. A friend has a 60mm Mazzi crank that is lightly used, bit cheaper than new. (a little worried about mazzi quality nd being lightly used)
2. Buy a new worb5 or pinasco crank, other suggestions?
From what I have read here, a few other places, and first-hand experience from a friend it sounds like this would provide some benefit now and more later if/when I decide to run a kit.
Is there a standard size spacer used at the base of a stock cylinder if using a 60mm crank? I have two heads, on stock, one has been modified for a better squish and higher comp. Gasket on the head either way?
