I just found out my pm pipe shoots out blue flames when it backfires...oh how I love this pipe!
Anyone know the best way to make it happen on command?
And how bad is it to rev the engine so the clutch engages and keep the brakes on?
Anyone know the best way to make it happen on command? And how bad is it to rev the engine so the clutch engages and keep the brakes on? |
Posts: 15002 Location: The state of insanity, SoCal |
Re: how to make the PM pipe backfire?
bryanhayn wrote: And how bad is it to rev the engine so the clutch engages and keep the brakes on? best, -greasy |
fluffy bunny
Posts: 2099 Location: Melbourne, Australia |
I find that riding past the local police station is the most reliable way to make the scooter backfire.
"Hello boys!" |
fluffy bunny
Scoots wrote: Scooterrific wrote: "Hello boys!" |
Scooterrific wrote: Scoots wrote: Scooterrific wrote: "Hello boys!" best, -greasy |
fluffy bunny
greasy125 wrote: Scooterrific wrote: Scoots wrote: Scooterrific wrote: "Hello boys!" best, -greasy |
i don't think that you'll get any complaints. it seems that those who missed the first round have been chomping at the bit ever since!
keep it PG13 and, dare i say it, titillating... oh, and include a picture of your pipe. lest we go off topic. best, -greasy |
fluffy bunny
greasy125 wrote: i don't think that you'll get any complaints. it seems that those who missed the first round have been chomping at the bit ever since! keep it PG13 and, dare i say it, titillating... oh, and include a picture of your pipe. lest we go off topic. best, -greasy |
Scooterrific wrote: That would involve writhing around on a shagpile rug with christmas lights in my driveway. Hmmmm. then i realised that in aussie speak, this meant rolling about on a bath-mat with a flash light. *laughs* best, -greasy |
fluffy bunny
greasy125 wrote: Scooterrific wrote: That would involve writhing around on a shagpile rug with christmas lights in my driveway. Hmmmm. then i realised that in aussie speak, this meant rolling about on a bath-mat with a flash light. *laughs* best, -greasy |
fluffy bunny
Piaggio Fly 150 Yamaha Vino 125 Suzuki Boulevard S40
Posts: 247 Location: Pittsburgh, PA |
bryanhayn wrote: I just found out my pm pipe shoots out blue flames when it backfires...oh how I love this pipe! Anyone know the best way to make it happen on command? And how bad is it to rev the engine so the clutch engages and keep the brakes on? Running lean for an extended period of time will raise the operating temperature of the engine (which is air cooled to begin with) leading to premature component failure. Additionally, you will need to accelerate your oil-change interval to accomodate the higher operating temps which will lead to faster oil break-down. Unless you upjet the carb and retune the bike, all you've done is make it louder. |
Posts: 1303 Location: San Jose, CA, USA |
At least on my GT, the PM back/afterfire condition cannot be "tuned out" and is due to the freer-breathing exhaust. Mine pops when letting off the gas after high/higher revs, such as decelerating or engine braking (if there is such a thing with t'n'g scooters). My engine is tuned to PM's specs - factory Piaggio specs - and not running lean or rich, and I still get pops from the PM pipe.
To get the pop: rev up and let go of the accelerator! |
The backfire/popping is a result of the air/fuel mixture becoming very lean when the throttle is closed and the engine is rotating well above idle speed. This is often caused by an open exhaust or air-box mod.
When the throttle is closed (in the idle position), fuel does not flow out of the main system (needle, needle jet, main jet). Fuel is only delivered to the engine by the pilot (idle) system. The combined effect of the closed throttle and elevated engine rpm is to create a fairly strong vacuum in the intake manifold. This vacuum, combined with the higher than normal air-flow rate (caused by the open exhaust or air-box mod) force fuel through the small gap formed by the throttle valve and carburetor throat. Under these conditions the pilot jet cannot deliver enough fuel to create a normal air/fuel ratio. The mixture becomes too lean to burn reliably in the combustion chamber so it gets sent into the exhaust system unburned and collects there. Eventually, enough raw fuel accumulates to create the proper air/fuel mixutre. That then ignites in the exhaust causing the pop or backfire. Putting a 'free flow' exhaust on an otherwise stock engine will lean the fuel circuit WAAAAY out. Running for an extended period of time with this condition ( backfires included) CAN lead to exhaust valve failure (burnt valves) as well as cylinder/head temperature issues. The only solution is to retune the carb with larger pilot and main jets as well as adjust the needle and slide valves. |
I agree with you about running lean etc. with the PM exhaust, however even GTS's that have been set on a Dyno with a PM box and are definitely not running lean still pop on the over run! (as do alot of other correctly tuned vehicles with free flow exhausts). If it was popping every time you closed the throttle I would be a little concerned but a little pop here and there, I personally wouldn't lose any sleep over it.
The GTS engine in "stock" form runs very lean anyway to meet Euro3 emissions, that's why (even in stock form) the engine / exhaust get very hot. Also in losing the catalyst etc I think you get an acceleration gain with just the exhaust. My GTS with exhaust fitted would out accelerate Suit Scoots before he got his PM pipe. |
Our mechanic had a scooter that could backfire on the press of a button. It had something to do with either a fuel line, a spark plug, or possibly both going to the exhaust. Scared the bejesus out of me. I get the logisitics confused with the backfire button and the smoke screen button. I know the smoke screen button routed oil into the exhaust.
To get it to happen on a 4-stroke with an exhaust, you could lean out the air/fuel mixture screw to create a lean idle condition, but I wouldn't do it on a bike I cared about. Especially considering the fragile nature of aftermarket exhausts on the GTSs. |
hey max, hows the deal with PM UK going? you NEED to be the one to provide their products to the US.
oh, and about the pm pipe - there is definitely a performance boost...noticeable in the midrange. top speed isn't affected. |
Nyle wrote: imagine a world where all cars have flames spitting outta their exhaust....that'd be nice |
Babyarms wrote: I agree with you about running lean etc. with the PM exhaust, however even GTS's that have been set on a Dyno with a PM box and are definitely not running lean still pop on the over run! (as do alot of other correctly tuned vehicles with free flow exhausts). If it was popping every time you closed the throttle I would be a little concerned but a little pop here and there, I personally wouldn't lose any sleep over it. The GTS engine in "stock" form runs very lean anyway to meet Euro3 emissions, that's why (even in stock form) the engine / exhaust get very hot. Also in losing the catalyst etc I think you get an acceleration gain with just the exhaust. My GTS with exhaust fitted would out accelerate Suit Scoots before he got his PM pipe. |
Motorsport Scooters wrote: I know the smoke screen button routed oil into the exhaust. . |
Posts: 3752 Location: cleveland, UK. |
Kam wrote: Babyarms wrote: I agree with you about running lean etc. with the PM exhaust, however even GTS's that have been set on a Dyno with a PM box and are definitely not running lean still pop on the over run! (as do alot of other correctly tuned vehicles with free flow exhausts). If it was popping every time you closed the throttle I would be a little concerned but a little pop here and there, I personally wouldn't lose any sleep over it. The GTS engine in "stock" form runs very lean anyway to meet Euro3 emissions, that's why (even in stock form) the engine / exhaust get very hot. Also in losing the catalyst etc I think you get an acceleration gain with just the exhaust. My GTS with exhaust fitted would out accelerate Suit Scoots before he got his PM pipe. |
VP1 wrote: Motorsport Scooters wrote: I know the smoke screen button routed oil into the exhaust. . |
