@vmorris1921 avatar
2012 LXV 150, 2007 GTS 250, 2001 ET2 w/kit
@vmorris1921 avatar
My headlight cutting out every few seconds (ET2). It didn't go completely out but was very dim for a second. Do I need a new bulb? I did a search on this forum and couldn't find anything. Maybe it's a dumb question, but it's a real pain to get it to the shop. Is it simple enough to replace a bulb myself?
@bluebuddha avatar
Kitted ET4.
@bluebuddha avatar
Kitted ET4.
At first glance, without any information---I would think it may be a lose wire issue causing your light to flicker. If the bulb were bad---it would/should have completely burned out. If you open the headlight housing check the connections.....a wire might be loose.
@suit_scoot avatar
@suit_scoot avatar
had this on my gts, turned out the dimmer switch was knackerd.
hope this helps.
@jimh avatar
MV Saint
Haud yer wheesh't if ye cannae be nice
MV Saint
@jimh avatar
Re: Headlight flickers off for a second
Oh yes! This is a very simple job mate. Loose wire me thinks.
Don't go to a shop to have a bulb replaced, (Insert you thoughts here)
Pm me and i will talk ye through it over the phone.
That simple.
Cheers
@scooter_west avatar
Sponsor
Sponsor
Loose wire or connection somewhere.
@vmorris1921 avatar
@vmorris1921 avatar
Thanks for the replies. I'll be taking it apart this weekend.
[ Time: 0.0127s ][ Queries: 3 (0.0046s) ][ live ][ 318 ][ ThingOne ]
