Hi Guys,
Some update from Vietnam after 10 months owning my PX150.
While I am very happy with it, I had to fix many things to make it reliable, since it is my daily driver. So about a month after buying it, I have decided to bring it to a renowned Vespa mechanic in my area and simply told him to change whatever needed to be changed to make it work as it should.
Here are some main parts that has been changed or cleaned. I have few more pics if you want.
While the engine was running well after that, I kept having the carb flooded every morning. Especially when stopping with the engine hot, it was a pain to start again. The carb was leaking, I changed every gaskets, pins etc until I had enough and decided to replace the original carburator for a new one.
The old one (obviously lol)
I also had a flat tyre which was quite a scary experience since it happened in few seconds, I was lucky to be able to stop before crashing The tyre pretty just slipped out of the rim while riding... I went straight to the garage and bought 3 brand new Kenda tyres.
I replaced the handle grips, the rear light cover, every bulbs, the entire front fork with the wheel hub.
I kept having oil leaks problem with my rear hub, after changing the o ring 3 times, I have decided to change it entirely:
I also had a lot of oil coming from the exhaust connection so the mechanic arranged it a bit and I drop the oil mix from 5% to 3%, which solved the problem.
I rode a lot on weekends around my area (Dalat, in the moutains) and got some cool shots
I also go often to the beach, which is about 3h ride (Phan Rang or Nha Trang), here are some pictures:
Overall, I am delighted to ride it everyday. It works very well now and I enjoy spending time improving small things myself on it.
Of course, in the end I got scammed, big time. The bike was worth less than I paid for because the seller lied about it and I did not know better. I had spent half of what I paid for just to fix it and the resell value probably hasn't improved. So if I had to sell it now, I will definitively lose money. But that's ok, it's a great experience overall, about Vespa and about living here. It's not the shiniest, the most valuable or the rarest but it got the spirit and its fault are part of its charm for me now.
Next step is a new CDI (or ECU in english ? the thing below the carburator, on the back of the engine) and probably a repaint soon since rust is appearing. I was also thinking about changing the handlebar cover with the speedo to put a real italian PX one but I honestly prefer the one I have, the design is, in my opinion, much nicer. After all it's a PGO, I don't intend to hide that. But the speedo is broken and it's very hard to find a Taiwanese one so.. I still have to decide what I want to do.
Hope my pictures entertained you a bit
Ride safe !
