I have a question about my new GT200. From the information I've received on Modern Vespa as well as things I've read elsewhere, including Vespa's web site, I expected my scoot to acheive at least an indicated 75 mph, which would be roughly 68 actual mph. My personal experience, however, does not bear this out.
When doing a top speed run on a flat surface, my scoot tops out at 60 mph indicated, which is probably around 54-55 mph actual, far short of my expectation. I should note that I live at 5300 ft altitude, so I know that the engine makes 20% less hp than it would at sea level, but the thinner air is also easier to push through, so I wasn't expecting the hp deficiency to have such a drastic affect on the top speed. While a differnt animal, my experience with automobiles at 5300 ft is that the acceleration rate suffers as a result of the higher altitude, but the top speed does not.
I should also note that I did my top speed run in the standard sitting position -- I made no effort to tuck down in an effort to streamline myself. Perhaps the advertised and discussed top speed on these scoots is a function of a rider in a tucked position.
The only other thing I can think of is that the scoot is running too rich as it has not been rejetted for my altitude. While a rich condition can rob power, I did not anticipate such a pronounced effect -- particularly since the scoot seems to run perfectly otherwise.
So, am I expecting too much out of this scoot, or is something else going on? Any thoughts?
Thanks.
-Dave
