Hey guys,
on my allstate's carb, the left side (sitting facing the engine) on the bottom right above the gasket where it mounts to the engine there is a small brass screw with a spring over the threads to keep it in tension i assume. what is that screw for? there is a plastic "plug" in the carb box that can be unscrewed so that screw can be accessed without taking the carb off. thanks-Todd
