Vespa PX200
Vespa PX200
Had a go at fitting my SIP speedo today and came up against a few problems.
I have the speed sensor converter to replace the speedo cable but it doesn't look like it fits, does the part under the rubber seal come out? I can't seem to find a definitive answer but I have seen a mention of a top hat which could be the issue I have.
The other problem I have is finding a 12V source for the speedo to run. It has had the battery removed so is running AC, in the manual it says to find the headlight power wire, does this mean the wire going to the headlight switch?
I've given up for the day as I was getting frustrated and probably pissing a few people off as I have to have it running to find the right wires Laughing emoticon
I may also have another issue with the headlight switch itself but I'll save that for another day
@rowdyc avatar
@rowdyc avatar
That speedo sensor in the picture is used with a magnet that rotates with the wheel. Just use your original speedo cable.
12v source from the headlight is at the headlight and not the switch. Tap into the wire that goes to the headlight.
Good luck.
parallelogramerist
parallelogramerist
Yes, the part that's under the rubber seal slides right out. It should come out fairly easily. Maybe hook it with a dental pick or a small screwdriver to fish it out.
Vespa PX200
Vespa PX200
Good luck.
Original cable is knackered hence why I bought this one to solve any future issues with cables. Ironic that I'm struggling with it really Crying or Very sad emoticon
Thanks for wiring pointer, according to the wiring diagram I have that should be the purple wire but I'll have a test with the multimeter first
Thanks I'll give that a go in a mo
Vespa PX200
Vespa PX200
Had some success, speed sensor is now in
@christopher_55934 avatar
2007 Stella 225
2007 Stella 225
What did you have to do? Going to be looking at mine today as I need to order one for mine to work.
parallelogramerist
parallelogramerist
Here's a pro tip...
that hex head screw that retains the metal backing plate for the speedo's rubber seal?...replace it with a socket head cap screw. It's easier to fit a "ball end" allen wrench than a socket or a wrench.
@gravelrash2004 avatar
P Series / Li / LML / Motovespa
Here's a pro tip...
How have i missed this trick over the years....... nice suggestion....
if only i had had it 30 years ago i would not have skinned so many knuckles and uttered so many choice expletives
Vespa PX200
Vespa PX200
I couldn't get the top hat out of the housing. I needed a set of long reverse pliers really but ended up using all manner of picks and bits of wire and got there in the end.
Here's a pro tip...
Amazing tip, why didn't I think of this myself before I put it all back together?!
I'll do it next time Laughing emoticon
Now just to get the speedo wiring itself sorted which I think I've figured out
[ Time: 0.0101s ][ Queries: 4 (0.0029s) ][ live ][ 334 ][ ThingOne ]
