I have just finished converting my 180 Rally to electronic ignition. In the process it was also converted to 12V.
I used a P200 flywheel from which I removed the center piece. I then had it machined so that the existing flywheel rotor (on the 180) fitted perfectly.
I also used a P200 stator, but had do some machining and filing at the backside to make it fit on the engine. To get the correct timing (22°), I also had to lengthen the screw slots on the statorplate.
It now runs like a dream, but I have been wondering: does the electromagnetic field generated by the rotating flywheel have an influence on the timing light? Why I ask is because the timing was about 15° out when I checked it, hence the machining of the screw slots.
For those who have been wondering: I marked the position of the keyway on the P200 flywheel before I removed the center piece, and I made sure that the rotor's keyway aligned perfectly after assembly. So, why was the timing still so much out?
