Fri May 22, 2020 12:39 pm
2007 Stella 225
2007 Stella 225
Fri May 22, 2020 12:39 pm linkquote
Can someone explain how the Clauss Studio upper shock to frame mount works? Anybody have an installed picture of one?
https://www.claussstudios.com/store/p540/Vespa_Rally_P200_PX200_HD___P125_Stella_Super_Sprint_GL150__GS160___SS180____Shock_to_Frame_Mount_.html
Last edited by Christopher_55934 on Sat Jul 04, 2020 6:39 am; edited 2 times in total
Fri May 22, 2020 12:53 pm
Fri May 22, 2020 12:53 pm linkquote
It gets held in by two attachment points. You have to drill a second hole in you frame to mount it up in there. If no one else posts up a pic I can probably take on later today.
Fri May 22, 2020 4:37 pm
2007 Stella 225
2007 Stella 225
Fri May 22, 2020 4:37 pm linkquote
I saw a Piaggio mount it looked like a piece of rubber stuck between two sheets of metal. Does the Clauss mount replace the piece of rubber completely?
Fri May 22, 2020 5:13 pm
Fri May 22, 2020 5:13 pm linkquote
Yes, the Clauss mount replaces the stock one. The Clauss is a beefed up version of the rubber block. Instead of the rubber + 2 metal plates top and bottom. The clauss version encapsulated the rubber on 4 sides, and provides extra support around the shock extension. To mount it you use the already existing hole in the frame, and drill and additional hole next to it. Stronger support to frame, stronger support to shock mount, and uses polyurethane instead of rubber. Provides firmer tighter suspension, but some say at the sacrifice of comfort; as it transfers more vibrations to the frame.
Fri May 22, 2020 5:45 pm
Vespa
Vespa
Fri May 22, 2020 5:45 pm linkquote
I have one on my P200 and GL no complaints
Fri May 22, 2020 6:25 pm
Fri May 22, 2020 6:25 pm linkquote
And now for pics...
***EDIT: I just realized that i'm holding up the shock mount so it's 180 degrees off. So if you turn it 540 degrees the other direction, it will be correctly situated.
Fri May 22, 2020 6:26 pm
Fri May 22, 2020 6:26 pm linkquote
Another pic
Fri May 22, 2020 6:27 pm
Fri May 22, 2020 6:27 pm linkquote
I don't know what happened here
Fri May 22, 2020 6:28 pm
Fri May 22, 2020 6:28 pm linkquote
FOR SALE: slightly used shock mount...
Fri May 22, 2020 6:41 pm
Fri May 22, 2020 6:41 pm linkquote
Whodat - LMAO.
You went to do a good deed and shoot a pic - and ended up with a full blown fixit project.
Thanks for the chuckle.
Christopher - I am using the PLC lower mount to replace the rubber at the back of the motor. No noticeable change in vibration. (PLC are through SIP and others).
Considering upgrading the "silent block" motor mount to either Clause or PLC or other. Dont really want to have a jarring ride - but looking to weed out any unwanted wobbles at speed.
Whodat (and others) what's the word on the various versions out there from PLC/Clause/others?
https://www.sip-scootershop.com/en/products/rubber+engine+mounting+bushs+_17472620
Fri May 22, 2020 10:24 pm
Fri May 22, 2020 10:24 pm linkquote
charlieman22 wrote:
Whodat - LMAO.
I've heard LOTS of complaints about poly engine mounts and vibrations. I do mostly highway commuting for at least 30 miles at a time so riding comfort is important to me. I have three sets of Clauss poly bushings. One in a T5 172, one in my pink PK200EFL, and one in a PX215. I don't notice vibrations in my PX215 or PK200. Who's to say how much vibration the poly creates in the T5 since i have a SIP carbon fiber race seat on it (no foam). 100 mile trips are already unpleasant from the seat, so i don't notice much else.
I have those orange PLC in my red PK125XL build PK smallframe touring cylinder options (Page 4) I'm not finished with the build, so i can't say how they feel. I think they have two different durometers?...green ones as well. I like orange so i bought orange. Charlie, your scooter needs the orange ones! I think the orange flavored PCL mounts are a little bit softer durometer than the Clauss. When i performed a scientific side by side "bite test" a few months ago, the orange tasted softer than Clauss black. *(i think he might make blue flavored ones now? I have zero experience with that variety).
I also saw some super trick swingarm bearings. I was thinking about getting those for my pink PK, but i figured that the bearings would get wet and rust at some point. If they were available years ago, i definitely would have installed them in my T5 track bike. I have some other PX's as well that still have the stock rubber bushings. Those are nice and "Cadillac cush" for sure.
I'm not really a fan of anyone's lower rear poly shock mount yet. The bushing seems to float around in the mouting hole in the case, which causes the shock mount to rub against the case mount. I haven't had an issue with that when using the original rubber bushings.
I think sometimes poly bushings can bring other things to light...such as if you have a crank that's a little bit out of balance, then you go and install some harder durometer engine bushings, and poof!...instant vibrations galore!
Sat May 23, 2020 1:19 am
Sat May 23, 2020 1:19 am linkquote
I have the Clauss uppers, and also run Clauss Mounts (blueberry flavor) in both my Stella and Sprint motors.
I don't notice vibration in the Stella motor, but do notice more on the Sprint motor.
I'm about to re-assemble my VBB motor with regular rubber mounts, so I'll have a basis for comparison after that.
And, in case you were wondering, installing that Clauss upper mount was a brutal project in a bike that wasn't a bare frame.
Sat May 23, 2020 3:19 am
2007 Stella 225
2007 Stella 225
Sat May 23, 2020 3:19 am linkquote
You definitely should not be their sales person. That doesn't make me want to spend 3X more on a shock mount that requires more work to install.
Sat May 23, 2020 3:23 am
2007 Stella 225
2007 Stella 225
Sat May 23, 2020 3:23 am linkquote
Did the mount come with installation instructions? Going to email and ask them about getting a set.
So the factory rubber part screws into the frame, then the shock screws into that. The Clauss mount has two mounting holes and the shock screws into that.
Sat May 23, 2020 3:41 am
Sat May 23, 2020 3:41 am linkquote
I don't recall it coming with instructions, but I put it in a few years ago when my factory mount broke.
The Clauss mount has two holes, so you re-use one hole and drill a new hole for the second mounting bolt. Then you screw the shock+spacer onto the mount like you normally would.
Sat May 23, 2020 4:35 am
2007 Stella 225
2007 Stella 225
Sat May 23, 2020 4:35 am linkquote
https://www.claussstudios.com/store/c46/vespa.html
Anyone know the diameter needed for a Stella rear engine shock mount bushing? Two sizes listed 9mm or 10mm.
Sat May 23, 2020 4:37 am
2007 Stella 225
2007 Stella 225
Sat May 23, 2020 4:37 am linkquote
Do I want to know why it was brutal? I have a few drills including a right angle if that helps.
Sat May 23, 2020 7:26 am
Sat May 23, 2020 7:26 am linkquote
Christopher - appreciate you letting me borrow the thread a bit for additional feedback/update from those using. Been looking at these simultaneously - but hadn't considered that top mount.
Just curious - what are you looking to improve by using - is the bike doing something specifically?
Whodat! Gracious. Dissertation is excellent. Tks!
Chandlerman - Kinda interesting that one bike is less smooth with them than the other.
Will be interesting to see if you prefer the "Cadillac" ride vs the sport suspension feel when you rebuild with new.
I put some BGM ones in on my last build - extremely cushy feel - but find them too squishy from a "control" standpoint. Softer than the LML style with metal tube on OD.
Sat May 23, 2020 8:02 am
2007 Stella 225
2007 Stella 225
Sat May 23, 2020 8:02 am linkquote
I was curious more than anything, looking at putting on some new shocks and was looking for other maintenance parts that should be replaced. The upper shock mount was one of them. When I did a Google search this came up.
Last edited by Christopher_55934 on Sat May 23, 2020 9:18 am; edited 1 time in total
Sat May 23, 2020 9:00 am
Sat May 23, 2020 9:00 am linkquote
I wasn't the mounts fault. My riding style lends to taking LOTS of shortcuts to get to point B on my commutes....straightening the curves, flattening the hills sort of stuff.
Sat May 23, 2020 6:34 pm
1964 GS 160 MK II, 1967 Vespa GT, 1968 SS180, 1964 Vespa GL, 1964 Vespa VBB, 2006 Buddy 125, 2013 BMW C650GT
Sat May 23, 2020 6:34 pm linkquote
Installing the CS mount is pulling the tank and drilling a hole then one extra nut and bolt.
Sat May 23, 2020 6:58 pm
2007 Stella 225
2007 Stella 225
Sat May 23, 2020 6:58 pm linkquote
Yet another reason to install a new set of fuel hoses and fast flow fuel tap sitting in a box.
Sat May 23, 2020 11:36 pm
Sat May 23, 2020 11:36 pm linkquote
With many bushing swaps over the years, i now just drill out the lower shock mounting hole to be able to utilize the larger diameter bolt.
Sun May 24, 2020 7:37 am
P Series / Li / LML / Motobi
Sun May 24, 2020 7:37 am linkquote
I run a full clauss setup on my purple scoot
Top shock mount (rear)
Bottom shock mount (rear)
Engine Mounts
front shock (top)
it feels really "planted" with this setup. not air ride soft, but less engine vibration and better control that a set of worn bushings they replaced thats for sure
I replace all the lower bushings in mine with the 10mm variety. but thats so i have a consistent bush throughout all my scoots and can swap engines over from one to the other without any issues. been caught out in the past when a 9mm bolt made a bit for freedom and all i had were 10mm bolts.. you get the idea
oh and the best part..... If you wear or damage then from use, they will replace them free as they have a lifetime warranty
Sun May 24, 2020 8:50 am
Sun May 24, 2020 8:50 am linkquote
Good Feedback everyone. i have a full set of these on the shelf, waiting to go in. I wish they made a shock top and front top bushings for the Smallframe.
Sun May 24, 2020 11:24 am
Sun May 24, 2020 11:24 am linkquote
depending on the model, im fairly certain PX parts can be fitted
Sun May 24, 2020 11:37 am
Sun May 24, 2020 11:37 am linkquote
Will for sure on the PK front shock
Sun May 24, 2020 11:46 am
Sun May 24, 2020 11:46 am linkquote
the rear suspension looks to be common across a large swathe of the smallframe range
https://www.sip-scootershop.com/en/ersatzteile/spare+parts++vespa+50pvet3pkxl-577/centre+stand+brake+pedal++shock+absorber+rear-624?
so a mix and match of parts on clauss site could/should yield a full rear suspension upgrade
NICE
Sun May 24, 2020 12:23 pm
2007 Stella 225
2007 Stella 225
Sun May 24, 2020 12:23 pm linkquote
They look easy enough except the engine mount, you have to pull the motor completely out it looks like. Then getting the bushing out can be fun, from the videos I've seen.
Last edited by Christopher_55934 on Sun May 24, 2020 1:41 pm; edited 1 time in total
Sun May 24, 2020 1:28 pm
Sun May 24, 2020 1:28 pm linkquote
Just pull the tank and yeah, change the hoses, tap and just clean up in there.
I always sign and date inside the tank area for someone to fine someday!
Sun May 24, 2020 7:05 pm
Sun May 24, 2020 7:05 pm linkquote
NICE
The oem rubber block is the same, but my SF has a reinforcing rib molded into the frame, directly adjacent to the block. So the Clauss mount would only fit if this rib is partially cut out. Yes, It would fit, but I don't want to cut the frame this way. I'll have to look again and see if there is another way to make it work without permanent modifications.
The Front shock Top buffers may work OK, but the P-series buffers are larger Inside & Outside diameter. I'll have to compare to see if it can be made to work safely. Outside diameter can be cut down to fit in the mount cup, but I feel like there is too much play on the larger Inside diameter. The top shock bolt 'floats around' Inside the buffer, and can contact the metal mount plate.
Sun May 24, 2020 7:08 pm
Sun May 24, 2020 7:08 pm linkquote
I'm referencing how these fit on my '81 100 Sport
Sun May 24, 2020 8:07 pm
Sun May 24, 2020 8:07 pm linkquote
NICE
You mean exactly like the same rib that's on a P? Take a second look at the pics above that I posted. I can't remember if the clauss mount comes with spacers to drop the bracket down below the rib. I suppose if not, a guy could easily do that. In fact, the mount might come with a notched poly spacer that accounts for that rib? Mine broke years ago, so it's been a while since I messed with one.
Sun May 24, 2020 9:38 pm
Sun May 24, 2020 9:38 pm linkquote
NICE
The 'rib' on my SF is much more pronounced than the Pseries/large frames. Its actually a pinched weld seam where 2 different pieces of the sheetmetal join together. Its approx 1/4" tall. A spacer/riser could easily work, if there is enough thread on the clauss block 'welded bolt'. I have a brand new Clauss mount for another project; so 'll check for fit on the SF
Mon May 25, 2020 5:26 am
Mon May 25, 2020 5:26 am linkquote
"Vespa"
https://www.sip-scootershop.com/en/products/rubber+buffer+shock+absorber+_17815000
https://www.sip-scootershop.com/en/products/rubber+buffer+rear+top+lower_17814900
These seem to be the equivalents
"Clauss Studio"
https://www.claussstudios.com/store/p545/Vespa_ET_LX150_S_Polyurethane_Rear_Shock_Bushings.html
https://www.claussstudios.com/store/p542/Vespa_GTS_GTV_250_300_Polyurethane_Upper_Rear_Shock_Bushings.html
Please bare in mind - i dont have a smallframe anymore so "caveat emptor" as they say
https://www.claussstudios.com/store/p541/Vespa_PX_ET_LX_150_MP3_GTV_250_Polyurethane_Front_Shock.html
Its really niggling me, as in, im sure someone has used part of this set as well to replace a top bushing on the rear mount..... i just cant find the evidence at the moment to support the assumption
NICE
Mon May 25, 2020 7:31 am
Mon May 25, 2020 7:31 am linkquote
One semi-random suggestion, make sure you have a ratchet end 13mm wrench and the job will be a lot easier.
Mon May 25, 2020 5:35 pm
Mon May 25, 2020 5:35 pm linkquote
Good advice. ratcheting wrenches are the best!!
Mon May 25, 2020 6:41 pm
Mon May 25, 2020 6:41 pm linkquote
x2! They're a game changer for that upper shock mount bolt.
Mon May 25, 2020 10:35 pm
Mon May 25, 2020 10:35 pm linkquote
X3!
I bought them in all sizes from 6mm to 17mm. Total game changer. Love my socket set and ratchet spanners
Tue May 26, 2020 2:37 am
2007 Stella 225
2007 Stella 225
Tue May 26, 2020 2:37 am linkquote
I own two sets of ratcheting wrenches. A flat set and an offset set, the offset set never seem to be at the correct angle for me. I want to get a set of flex head like these.
https://www.homedepot.com/p/husky-100-position-flex-head-ratcheting-wrench-set-metric-6-piece-h100flrw6pcmmn/301175139
  DoubleGood Vespa T-Shirts
[ Time: 0.0530s ][ Queries: 28 (0.0327s) ][ Debug on ][ 201 ][ Thing Two ]
