Fuoco 500
Fuoco 500
Hello everyone !
I have recently purchased an old 2008 Fuoco 500.
Before this, i rode a Honda Rebel 500 but i wanted a maxi scooter and boy, the fuoco 500 was love at first sight even though it is a pretty old model now.
They are so rare these days but i managed to snag one after months of scouring the web and classifieds.
Anyway i have a problem. Was using the tilt lock one day and heard a soft snap. Since then there has been a clanking noise whenever i engaged the tilt lock (It still works).
I opened it up, and discovered a joint which pushes the hydraulic piston has snapped. It seems to be a ball and pin joint of some sort. Here are some Pictures.
I am h aving a hard time finding the part number. Has anyone had a similar problem ? could i fabricate something myself to replace it ? Is this part expensive and difficult to replace ? Thanks ahead !
The parts diagram isn't that helpful, is it.
https://manuals.wotmeworry.org.uk/Gilera/Gilera%20Fuoco%20-%20MP3%20500/
What does the other side look like, and can you fabricate something to do the trick?
contact Maksor here on the site. he might have what you need.
Piaggio MP3 ie 400 (RIP)
Fucoc 500 tilt lock...
Hi,
You did not mention if you tried to contact wreckers, you may find one with the front system...
Good luck.
@web-tech avatar
@web-tech avatar
PM me if you need a part, I have a broken tilt lock mechanism I can take parts off.
Not sure how to get to that part to remove it from the housing, but should be able to figure it out.
[ Time: 0.0112s ][ Queries: 4 (0.0039s) ][ live ][ 334 ][ ThingOne ]
