Hey ALL !
Got rebuild going on small frame Vespa '90. New bearings all around and new crank & piston (DR 130 kit). Here's the question putting everything back in case and I was wondering if a slight space / play in gear shifter (see pictures) is normal? My shims and circlips (front & back) are all there. Gears look like they are almost brand new and the shaft has little to no signs of wear. The gears line up with the input shaft no problem.
My only concern before I close case is .. should gears be able to slide back and forth on shaft with some slight amount of space between the front & back shims (see images).
I look forward to your response.
THX
Boo
