sp949 wrote:
Is there a logic or meaning regarding the color and letter codes on P/PX regulators?
My US PX150E Elestart has the following colors/ letter codes on the regulator:
2 grey wires, letter codes A (dedicated lighting coil in out)
1 yellow wire, letter code G (A.C. Output from stator)
1 white wire, letter code B+ (looks like it goes to a bunch of stuff)
2 black wires connected together, no letter code (Ground wires)
I ordered a regulator from India to keep as a spare, which specifies in the ad that it is for Stella/electric start PX, and the colors/letter codes are :
2 red posts, letter coded G (
1 yellow post, letter B+ (battery +)
1 yellow post, letter C (
1 black with the ground symbol (Ground)
If I replace the unit, do the grey wires from the original go to the G posts?
The B+ has to go to the same B+ as in the original, I am assuming?
The yellow wire to the C post?
Black wires to the ground symbol post, I am assuming?
Will the new regulator work, or is any rewiring necessary?
Here are the two electrical schematics, maybe you can figure it out.
Wiring diagram electric start and battery.
https://www.scooterhelp.com/electrics/pages/VNX2T.px125e.html
Stella wiring diagram
http://www.lmlparts.co.uk/LML_STAR_2T.html#wiringdiagram
http://www.tassoparts.co.uk/LML_STAR_DELUXE.html
The Stella does not have a dedicated lighting coil. A Vespa has a dedicated lighting coil. Two grey wires
The Stella charges the battery using the regulator. The Vespa uses a dedicated coil, not connected to regulator.
I have a 2007 Stella with a battery and electric start, those colors don't match mine or my wiring diagram so I'm not much help. I rewired mine to work with a P200 stator, that's how I know the Stella connects all its coil into a single series input for A.C. from the stator, the one Yellow wire. Then the regulator distributes power to various circuits including charging.
Yellow - input from stator
Black - ground from stator
Red - dc out to charge battery
Grey - lighting circuit AC
Violet - lighting circuit DC, keyed controlled 12 volts from ignition key.
This doesn't match what you have either.
https://www.scooterwest.com/genuine-scooter-parts-and-accessories-1223/spare-parts/p-px-ac-dc-regulator-rectifier-12v-5-pole-2940165.html
